Page 1 of 2 12 LastLast
Results 1 to 6 of 7
Thread: Cinema Connection Kit Not Connecting to 'hidden' wireless network
  1. #1
    Join Date
    Feb 21st, 2012
    Location
    Tennessee
    Posts
    7
    Post Thanks / Like
    Having an issue with the Cinema Connection Kit (DCAW1R0-01) not connecting to the internet on my network. A little background on this issue: With the SSID name broadcast enabled on the router (netgear) the CCK was connected to the internet normally and successfully using the WPS buttons on the router and the CCK. The WLAN light (and other 3 lights) were lit on the CCK. Everything ok. When the SSID broadcast was disabled on the router (after the successful install of the CCK on the network) the WLAN light is now not lit up and the CCK is not connected to the internet.
    1. Does anyone know where I can find a manual for this newer CCK?
    2. Is there a Pin number on this CCK device that I can use to add it as a 'client' on my network using the netgear user settings?
    Going into Menu on the HR34 using the remote and Setup, I find the IP address and subnet mask info is all filled in ok. Going to System Info & Test, under info there is a yellow ! beside STB Services Port: N/A (205) message there and another yellow ! is beside Internet: Not Connected.
    An earlier version of the CCK, the DCCK has a manual on the web that I found and it had a way for users of hidden wireless network name (SSID) networks to manually enter the SSID and the security key, etc as one might do on other devices. (For example iPads as I have done.)
    Hopefully I have supplied enough info here for someone to assist. Thanks!
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
    Reigster at SatelliteGuys
  3. #2
    jcrandall's Avatar
    jcrandall is offline Proud Staff Member
    Proud SatelliteGuys Staff Member
    Proud Staff Member
    Join Date
    Apr 3rd, 2005
    Location
    Central Michigan
    Posts
    9,778
    Post Thanks / Like
  4. #3
    Join Date
    Feb 21st, 2012
    Location
    Tennessee
    Posts
    7
    Post Thanks / Like
    Thread Starter
    That link is to the earlier model of the CCK, the DCCK. Not the same.
    Thanks though.
  5. #4
    Join Date
    Sep 4th, 2007
    Location
    Phoenix
    Posts
    130
    Post Thanks / Like
    Gamer IDs
    PSN ID: Straybeat
  6. #5
    digiblur's Avatar
    digiblur is offline Proud Staff Member
    Proud Staff Member
    Join Date
    Jun 8th, 2005
    Location
    Louisiana
    Posts
    14,207
    Post Thanks / Like
    What is your reasoning for using a hidden SSID?
    Just speaking in general here... some people believe a hidden SSID offers some sort of security. It offers no security at all. The same goes for using the MAC address authorization options. Your "hidden" SSID name is broadcasted out all the time when data is sent. Firing up Kismet will show your SSID to anyone along with any of the MAC IDs sending/receiving data. Enable WPA2 AES (not TKIP) and put in a nice long password that is not in the dictionary and you'll have some very solid security without having to fool with MAC IDs or issues with hidden SSIDs.
  7. #6
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! BobStokesbary did! Help Support The Site And Get Rid of the Syndicated Ads, BobStokesbary did! If you enjoy the site consider supporting it, BobStokesbary did! Be COOL like BobStokesbary and Click a Star and become a Supporting Pub Member today!
    Join Date
    Jul 9th, 2009
    Location
    Southern California
    Posts
    469
    Post Thanks / Like
    The OP has posted his question on 3 forums and is not responding to any of them. His reason for having the hidden SSID is that he is in some sort of commercial environment that requires the SSID to be hidden. Obviously he has control of the situation since he was able to do the WPS setup with the SSID visible. He is convinced that there are two wireless CCKs out there and the link to the manual given above is not good. He apparently reached this conclusion because he cannot get the "hidden SSID" prompt to work. On another forum I suggested that he reset the CCK and start over. And, as I said before, he has not responded. I consider this a dead thread.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
