Results 7 to 12 of 179
Thread: Newbie needs help....
03-15-2012 10:19 PM #7
Here ya go, great dish/LNBF w/shipping:
36 Inch 90 cm Free To Air FTA Satellite Dish & HD LNBF (890963002636) | eBay
Get rid of this ad below, as well as the link redirect by becoming a Supporting Pub Member
C-Band: 12' Unimesh/AJAK 180/GeoSat C2***10' "Perfect 10" mesh/GeoSat C2*** 8.5' Birdview solid/BV H-H/GeoSat C2*** 7.5' Unimesh/CalAmp voltage-controlled LNBF***...C-Band LOS from 58W-139W
Ku-Band: 3ABN .9m/SL1PLL LNBF/SG2100***Fortec .9m/TrackerII LNBF/STAB HH90***7.25' Birdview "Spoon"/TrackerII/70:1 BV H-H***Prodelin 1.8m/GeoSat Bullet/AJAK 180 H-H***Paraclipse Hydro 1.5m Prime Focus/Linear Actuator/C120 LNBF...Ku-Band LOS from 30W-129W
Receivers: Toshiba TRX-1820 Analog-->AZBox Elite/Openbox S9 HDx2***GeosatPro microHD
OTA Digital: CM 4228/CM 7777 Preamp/Apex DT-250 for OTA Locals, Toshiba 46" Regza & Toshiba 19" LCDs
In Progress: (2) Birdview 8.5' (1 solid & 1 perf) w/Birdview H-H mounts, "Drake" 10' solid alum....*BVOC Asst. Cook & Bottlewasher*
03-15-2012 10:19 PM # ADS
Register Today & This Ad Goes Away! Syndicated Advertisement- Join Date
- Always
- Location
- Advertising world
- Posts
- Many
03-16-2012 05:30 AM #8
SatelliteGuys Newbie
- Join Date
- Mar 15th, 2012
- Location
- Stone Mountain, GA
- Posts
- 4
- Post Thanks / Like
- Thread Starter
Thanks to all for your help. I think I will go or call Galaxy today their not that far and im sure they know the local conditions.
03-16-2012 10:52 PM #9
With the correct linear lnb, you can pick up some signals with the DTV slimline dish. I have been using one for years to get Hispasat 30W. Gets all the TP's on 30W and only fades in real heavy rain storms.
03-21-2012 06:29 PM #10
- Join Date
- Mar 15th, 2012
- Location
- Posts
- 4
- Thread Starter
Ok, any help with the Openbox S9. Got everything in place I feel like ya'll laughin at me. lol My breakdown is as follows: Signal Intensity: 45% Signal Quality 5%. 36" disc, DG 380 1.2 motor and a WS Int ESX521FE: LNBF. Purchased from Galaxy Markt. After hooking everything up nothing. Checked: LNB Freq, Transponder. Saw online a lot of people are having this problem and a site called Openbox.us, there support requires purchase from them. Elsewhere on line anyone posting their upgraded firmware seems to have been shut down. Any suggestons/support welcome to get whats needed to make this work if possible?
03-21-2012 07:10 PM #11
I've a hunch you're going to have to expand on what you've done so far to try to make it all work. 45% intensity and 5% quality means you have zero signal being received.
What azimuth are you pointing the dish? What elevation is the dish? Have you received any signal quality at all? What satellite / transponder are you trying to receive? What are your physical geographic coordinates (or zip code)? What firmware is in the S9? This site has some S9 firmware. I use a version that is not found on this site. I like 2011Aug30 version.GeosatPro microHD, Star Choice 40"x44" dish w/Multistar .3dB universal LNB, Moteck SG-2100 motor, Glen Martin RT-832 8-ft 4-legged tower
03-21-2012 07:16 PM #12First thing:
ADVERTISING BOX
Aiming a dish for the first time is not easy.
It's not Plug-N-Play.
99.99% of the time, the equipment is in proper working order.
That is a good thing - shows you have connected the cables correctly45% Signal Quality 5%
In the Receiver's Antenna Setup Menu, look for the LNB Freq. - it should be set to 10750, and Type:"Standard"ESX521FE LNBF
Look on the Motor Bracket, and make sure you have the Latitude Scale set to your LatDG 380 1.2 motor10' Unimesh w/ C Band Ortho Feed, GBox 3000, and Motorized 90cm "Bob Jones" Dish for Ku, with Omicom S2, TBS5925, TeVii 470, AZBox Elite, SatHawk PVR800.
Register To Reply
