Page 1 of 2 12 LastLast
Results 1 to 6 of 11
Thread: Hopper Remote Programming Issues
  1. #1
    Join Date
    Mar 24th, 2006
    Posts
    39
    Post Thanks / Like
    I have had a 722 and 922 and the remotes for them both program and work this tv just fine. I had to do the manual scan to find the code but with the Hopper Joey setup I cannot get this remote to work. SEIKI is not an option in the menu so I had to do that learn feature on the remote but I cannot get the power button to work. It appears that when you press power it just sends a pulse so the dish remote won't learn it. I really only need 4 buttons to work but can only get 2 to work. Volume up and Volume down works like a champ but input and power won't work.
    Any ideas on how to get this to work or a 4 digit code for the seiki TV. I find it hard to believe that while the other remotes had a code for this but the latest remote doesn't have the code.
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Posts
    Many
    Reigster at SatelliteGuys
  3. #2
    Join Date
    Sep 19th, 2010
    Location
    Southeast
    Posts
    757
    Post Thanks / Like
    The 922 32.0 remote uses the same codes as the Hopper 40.0 remote. If you still have it, pair your old 922 remote with the Hopper, and Remote Manager will show you the code, which should be TV 0178.
    But first, make sure you've disabled limited mode in Remote Manager. That can prevent other functions from working.
    Even if the power command is a short pulse, the 40.0 should have no trouble learning it. It's the NEC1 protocol which is very common and easy to learn. So if power still doesn't work with the above code (it should), you should give learning another try.
    Last resort, if you've ever had cable, a radio shack or one-for-all remote, you can use it to teach power using the same TV 0178 or 10178 code.
  4. #3
    Join Date
    Aug 9th, 2011
    Posts
    176
    Post Thanks / Like
    Quote Originally Posted by Kurto2021
    Are you trying to learn from your previous dish remote or the actual TV remote. In my experience if the dish remote is lighting up like a pulse, the batteries are critically low. Try using some new batteries. But yes, odd that Seiki isn't listed in the hopper.
    Probably a dumb question, but on the find your TV screen, you are searching alphabetically and not leaving it on the top setting of most common brands?
  5. #4
    Join Date
    Jun 1st, 2009
    Location
    Maryville, MO
    Posts
    304
    Post Thanks / Like
  6. #5
    Join Date
    Sep 19th, 2010
    Location
    Southeast
    Posts
    757
    Post Thanks / Like
    Thanks Brodieb. Site above confirms code is 0178 as posted earlier.
    FYI, when searching for codes elsewhere, Hopper remotes use the same codes as DirecTV and cable (right 4 digits), not old Dish codes.
  7. #6
    Join Date
    Mar 24th, 2006
    Posts
    39
    Post Thanks / Like
    Thread Starter
    I went through almost all those codes with no luck
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
