Quantcast
I NEED HELP PLEASE
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Welcome HOME to SatelliteGuys! We are America's Most Popular Satellite Forum!
Page 1 of 3 123 LastLast
Results 1 to 6 of 16
  1. #1
    Join Date
    May 3rd, 2012
    Location
    West Virginia
    Posts
    6
    Post Thanks / Like
    I NEED HELP PLEASE
    Ok I'm trying to install a Dish Sat. "Dish Network 1000" it has two different "signal recievers" (not sure what else to call them) one says "dp plus" it has two recievers n it (110w and 119w) the other one dosnt say what sat it is although I would assume it would be 129w well any way 119w has two places for coax cables and 110w has only one coax hook up so I assume I have to have at least one hooked up to each, the one I'm assuming is 129w has two places for coax, I was told that I need a dp 34 switch,
    im hooking this up at my river bak I'm only using one tv receiver in the camper it is a vp612 dvr
    Please help!!
    My questions are...
    1 what coaxes need to be hooked up!?
    2 do I have to have a dp34 switch can I just use a three way switch from Walmart?
  2. #2
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! HIFI did! Help Support The Site And Get Rid of the Syndicated Ads, HIFI did! If you enjoy the site consider supporting it, HIFI did! Be COOL like HIFI and Click a Star and become a Supporting Pub Member today!
    Join Date
    May 9th, 2007
    Location
    surfin SATGUYS in a round room with padded walls
    Posts
    8,650
    Post Thanks / Like
    Gamer IDs
    PSN ID: hifi454
    one cable from the smaller lnb to the single port on the dp plus, then a single cable from the dual side of the dp plus to the 612. be sure to run a check switch.
    In the end we're all just chalklines on the concrete
    Drawn only to be washed away
    For the time that I've been given
    I am what I am
  3. #3
    Join Date
    May 9th, 2007
    Location
    Posts
    8,650
    Post Thanks / Like
    Gamer IDs
    PSN ID: hifi454
    Dish1000.pdf try this for info.
    I am what I am
  4. #4
    MattG@ DISH NETWORK is here from DISH Network to help!
    Join Date
    Dec 30th, 2010
    Location
    Denver, Colorado
    Posts
    3,434
    Post Thanks / Like
    You don't need a DP34.
    Connect the single LNB (most likely a DP Dual that picks up 129) to the "input" on the DPP twin.
    Run one line from the DPP twin to the 612, and use a DPP Separator.
    Here's a wiring diagram. Ignore the receivers that they are connected to (and the "148" listed on the single LNB), and remember to use a Separator on the 612
    Click image for larger version.
  5. #5
    Join Date
    May 3rd, 2012
    Location
    West Virginia
    Posts
    6
    Post Thanks / Like
    Thread Starter
    Please put that in layman's terms. I'm an idiot ha ha.
  6. #6
    Join Date
    May 3rd, 2012
    Location
    West Virginia
    Posts
    6
    Post Thanks / Like
    Thread Starter
    ADVERTISING BOX
    Thanks dish network. I think I've got it now.
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
