Quantcast
211k Inital Problem
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Results 1 to 3 of 3
  1. #1
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! preynolds did! Help Support The Site And Get Rid of the Syndicated Ads, preynolds did! If you enjoy the site consider supporting it, preynolds did! Be COOL like preynolds and Click a Star and become a Supporting Pub Member today!
    Join Date
    Jan 10th, 2006
    Posts
    14
    Post Thanks / Like
    211k Inital Problem
    Just purchased a 211k and I am having problems in getting beyond the WARNING..Vital program information will now be downloaded into your receiver. Do not disturb or unplug the receiver until this screen disappears. My problem is the screen has not disappeared as it it stuck on the Status: Searching for information bar at the bottom. It has reached the 3/4 mark in green but has been stuck there for over two hours.
    Any suggestions? Can I unplug the receiver and start over again without equipment failure, turn the receiver off, remove and replace the wire to the sat? Thanks in advance for your suggestions. I have had many Dish receivers in the past and this is the first time I have every had any problem at all.
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Posts
    Many
  3. #2
    MattG@ DISH NETWORK is here from DISH Network to help!
    Join Date
    Dec 30th, 2010
    Location
    Denver, Colorado
    Posts
    3,434
    Post Thanks / Like
    Quote Originally Posted by preynolds View Post
    Yes, unplug the receiver to reset it. Once the receiver comes back on, you should be on the point dish screen. Make sure that you have run a check switch test, and that all satellites are coming in properly. After you do that, select done, and make sure that signal is "Locked" before selcting done again. It should then restart the software downloads (hopefully without issue).
    Matthew "Speedy" Gonzales
    DISH Internet Response Team
    I will be away for a few weeks... but like Arnold once said... "I'll be back!"
  4. #3
    Join Date
    Jan 10th, 2006
    Posts
    14
    Post Thanks / Like
    Thread Starter
    ADVERTISING BOX
    Thanks to MattG for your great tip. Receiver is activated and up and running thanks to your advice. Thanks again.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
