Quantcast
Anyone Using a USB Hub on Hopper
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Page 2 of 3 FirstFirst 123 LastLast
Results 7 to 12 of 17
  1. #7
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! Brussam did! Help Support The Site And Get Rid of the Syndicated Ads, Brussam did! If you enjoy the site consider supporting it, Brussam did! Be COOL like Brussam and Click a Star and become a Supporting Pub Member today!
    Join Date
    Nov 30th, 2006
    Posts
    507
    Post Thanks / Like
    Changing from the VIP722K to the Hopper, I had just a few recordings to transfer. I had a 80GB 2.25" drive is a case. I used a powered USB Hub to power the drive and both the &22K and the Hopper had no problem writing and reading the drive.
  2. #8
    Join Date
    Nov 25th, 2010
    Location
    GA
    Posts
    909
    Post Thanks / Like
    Quote Originally Posted by sparc View Post
    yes, but i doubt they made that rule with USB powered hubs in mind. They'll probably always assume you are direct connecting to be on the safe side.
    What's supported and what actually works is often different. Dish's published requirements are definitely on the conservative side - and I can't blame them for it. Non-powered hubs almost always seem to work. Non-powered drives not as much.
    There has been a lot of discussion on externally powered vs usb powered drive and the only real answer is it depends. With a powered hub, it seems to usually work, but I think some of the notebook type drives seem to power down too deeply and don't want to wake up.
    USB powered drives connected directly to the receiver have been a lot more hit or miss. Seems to depend a lot on the drive's power requirements and even which revision of the receiver it's connected to. Some drives are recognized, but don't seem to get enough power to actually spin up and do anything.
    Personally I would prefer putting the load on the hub's power supply than the receiver's.
    Of course all this experience in the forums has been for 622/722/722k. Hopper may have better (or worse) results in general.
    Bottom line, if you're purchasing a drive and can't return it, get a powered one to be safe. If you have a drive to experiment with, then try it out, but remember you won't get much help if it doesn't work.
  3. #9
    Join Date
    Mar 26th, 2012
    Location
    Chicago
    Posts
    27
    Post Thanks / Like
    Quote Originally Posted by JM42 View Post
    Which was exactly my situation. I had a spare EHD that didn't require external power sitting around and i thought it would be worth trying. It works (for now). Are you guys suggesting that it might crap out or kill my hopper?
  4. #10
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! KAB did! Help Support The Site And Get Rid of the Syndicated Ads, KAB did! If you enjoy the site consider supporting it, KAB did! Be COOL like KAB and Click a Star and become a Supporting Pub Member today!
    Join Date
    Sep 20th, 2005
    Location
    Indy
    Posts
    12,988
    Post Thanks / Like
    Quote Originally Posted by miracleman View Post
    They are saying take the load off the receiver's power by using a powered hub.
  5. #11
    Join Date
    Nov 25th, 2010
    Location
    GA
    Posts
    909
    Post Thanks / Like
    I doubt it, but I'm sort of a belt and suspenders type of guy. A little less load on the Hopper power supply means a little less heat, probably the receivers worse enemy, but the draw while idle is minimal. $12 for a powered hub and you don't have to worry about it.
  6. #12
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! navychop did! Help Support The Site And Get Rid of the Syndicated Ads, navychop did! If you enjoy the site consider supporting it, navychop did! Be COOL like navychop and Click a Star and become a Supporting Pub Member today!
    Join Date
    Jul 20th, 2005
    Location
    Northern VA
    Posts
    22,655
    Post Thanks / Like
    ADVERTISING BOX
    Neither my USB hub nor my EHD have their own power supply, and both work perfectly....
    But for how long?
    Yes. A larger load than planned on will strain a power supply and one day it might just push up daisies.
    Reunite Pangaea!
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
