Results 1 to 6 of 40
05-27-2012 09:07 PM #1
my first C-Band set up, need tips (Intelsat 9)
I have a the following hardware I would like to set up for Intelsat 9 @55 Degrees (location Belize, Central America):
* Sadoun 6 foot prime focus, solid
* A BCS 621 KU/C-Band Lnb
http://www.sadoun.com/Sat/Products/621-2manual.pdf
Get rid of this ad below, as well as the link redirect by becoming a Supporting Pub Member
* A Lexium DBS7000 C/Ku Sat receiver
I have never done a C band set up, only KU FTA with off set dishes.
Can anyone give me some guidelines ?
Q: is it linear ?
Q: the sat dish's manual does not indicate a focal point (the distance between center and focal point) Any idea ?
Q: is it measured from center to the tip of the feedhorn ?
Q: Search for signal: better with the signal meter or via the signal indicator on the receiver ?
Q: the receiver does not have Intelsat 9 preset; I added it (the name) manually but naturally there are now no transponders which i guess can be added once the signal is locked. Any advise on that ?
Q: receiver/sat set-up:
LNB type ?: standard, Universal, User
22K?: on or off
Polarity: H/V (I assume)
Thanks in advance,
Wolfgang
05-27-2012 09:07 PM # ADS
Register Today & This Ad Goes Away! Syndicated Advertisement- Join Date
- Always
- Location
- Advertising world
- Posts
- Many
05-27-2012 10:18 PM #2
I-9 is at 58W
Intelsat 9 at 58.0°W - LyngSat
I-805 is at 55.5W
Q: is it linear ?
A According to what lyngsat says, both are linear.
A. It can be calculated.
But I bet, the arms are at the correct length. Minor feed tweaking should be all that's left to do. Even the calculated is not perfect.
A. from the bottom dead center of the dish, the focal point is usually a 1/4 inch inside the feed throat.
A. Either work fairly well, although a meter is more convenient. No taking a TV and receiver out to the dish.
A. You must also enter an active transponder in the receiver, or meter, to lock on to, to get a Quality reading. THEN you can scan in other operational transponders.
Q: receiver/sat set-up: LNB type ?: standard, Universal, User 22K?: on or off Polarity: H/V (I assume)
A. BSC621 (NOT the BSC621-2) needs receiver programmed, for C Band reception. TYPE:Standard, L.O. 5150, 22Khz off.
For Ku: TYPE: Standard, L.O. 10750, 22Khz ON.
BSC621-2 uses DISEQC switch for band. 1 for C Band, 2 for Ku. Also change Ku LNB TYPE to Universal. L.O. should be 9750/10600 and AUTO 22Khz. (L.O and 22Khz may be set automatically with Universal selected)
(The above assumes the jumper is used as shown in it's instructions)
One night I walked home very late and fell asleep in somebody's satellite dish.My dreams were showing up on TV's all over the world. -- Steven Wright
Openbox S9, Pansat 3500SD, 139w to 55.5W +30W
10Ft USS Steel BUD and an assortment of P⭐ dishes, 84e(1), .7m(2), 1.2m(2). 2.4m[8ft](1) offset in storage. 🐱
05-27-2012 10:52 PM #3
- Join Date
- Jun 21st, 2009
- Location
- Belize, Central America
- Posts
- 113
- Post Thanks / Like
- Thread Starter
Great, this is more that I was hoping for . . .thanks !
Q: the lnb/feedhorn is a BSC621-2 C/Ku
Q: ref. A. You must also enter an active transponder in the receiver, or meter, to lock on to, to get a Quality reading. THEN you can scan in other operational transponders.
I played a few hours to get familiar with the receiver . . . I am not sure how to add transponders.
What would be a strong transponder I should add for an initial search ?
Thanks, Wolfgang
05-27-2012 11:40 PM #4
A straight c band lnbf will give you better performance on c band than a dual band lnbf
05-27-2012 11:42 PM #5
Very detailed guide you put out there, Fat Air.
AZBox Me, MicroHD, OpenBox S10 HD PVR Receiver, DVB-S2 CA USB 2104D and Coolsat 5000. DG-380 Motor (37.6°W to 125.0°W), on 1.2M Geosat Pro. 3ABN Dish @30.0°W. 2nd 1.2M looking @103.0°W. 6FT WSI Bargain Dish looking from 31.5°W to 101.0°W.
DishPointer
http://satcalculator.freehostia.com/index.php
Magnetic Declination Calculator
SatStar_Old Lyngsat Maps
VLC Player Tutorial
05-28-2012 01:02 AM #6Kinda confused yet as to which satellite you're looking for
ADVERTISING BOX
I-9 is at 58W
orGet rid of this ad below, as well as the link redirect by becoming a Supporting Pub Member
I-805 is at 55.5W
Transponders:
I-9 @ 58W - 3840 Horiz, SR 27690 or 4040 Horiz, SR 26590
I-805 @ 55.5W - 3695 Vert, SR 8888 or 3768 H 4427
BTW: I am also not sure how to add transponders into that receiver, no experience with that model. Also, I agree with Truckracer, a single band LNBF will perform better. The dual band types are a bit of a trade-off performance wise. Many have tuned them up on the primary band of interest and 'take what ya get' on the other band.
Register To Reply
