Quantcast
New Router Can't Connect to AzBox Premium Plus - Help Needed
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Page 1 of 2 12 LastLast
Results 1 to 6 of 12
  1. #1
    Join Date
    Jul 4th, 2006
    Posts
    1,032
    Post Thanks / Like
    Today I replaced my 7 year old D Link Router with a new TRENDnet Router and so far I can't connect my AzBox Premium Plus Rx to this new Router when it is Password Protected. When the TRENDnet Router is NOT password Protected it works fine with the AzBox. I have tried just about everything and Nothing will work to the AzBox when Password Protection is in on the TRENDnet Router.
    Also the WIFI password connection from the TRENDnet Router works to my Laptop, But not to my AzBox Rx. I have clicked on AzBox under Internet Connections for WIFI and Dynamic IP (DHCP) but when I Press "Setup" it says Not Able To Connect to Internet, also When I select System Info for the IP Setting it says 0000 Connecting?? Do I need to set up for Static IP, and do I need an IP connection for my new Wireless Connection? Also for my new Router the Listing is there for it on AzBox and it says: This Wi-FI requires Encription Setup. My Password for the Router was posted in the WEP Key Space, but it still doesn't work. Also does the WEP Key Password care if the ALL Caps are used in the Router Password ie is AzBox WepKey password case sensitive? Any help or advice would be much appreciated.
    Warning: This is an Old Thread
    This discussion is older than 90 days. information contained in it may no longer be current
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Posts
    Many
  3. #2
    Join Date
    Mar 19th, 2010
    Location
    southeast
    Posts
    1,129
    Post Thanks / Like
    If this is a new router, then I'd see how good their tech support is! I've used Dlink, Cradlepoint and Linksys routers and they were/are pretty simple to setup. Never used a TrendNet so I got no clue about those.
    I'd also consider making that AZBox IP static instead of dynamic if you're wanting to FTP to it. It's easier to do that if you already know the IP address and you don't have to make a new logins in Filezilla because that IP address never changes. After that connection is setup, FTP with Filezilla will just be a point and click from the "Quickconnect" drop down menu.
    10 ft Winegard, DMX-741S LNBF, VonWeise Mover, AZBox Ultra/Openbox S9 and PowerMax Vbox X.
    7.5 ft SAMI, DMX-741S LNBF, SuperJack Mover, AZBox Elite/Openbox s9 and PowerMax Vbox X.
    AND RANDY WILLIAMS (lying MOFO) GAVE MY 12FT CONIFER DISH TO SOMEONE ELSE!
  4. #3
    Join Date
    Jul 4th, 2006
    Posts
    1,032
    Post Thanks / Like
    Thread Starter
    Quote Originally Posted by Lone Gunman View Post
    Thanks a lot for the reply Lone Gunman. Trendnet's customer service were real helpful with my Desktop and Laptop's Router encripted connections, but the guy claimed he knew Nothing about Wireless Connections to Satellite Receivers. Mayby I'll call them again. I'll try the Static Connection also something doesn't seem right re my IP Setup on AzBox since when I go into "System Info" setting under IP it constantly says: 0 0 0 0 Connecting - so something is not right there. I do have Maz and ACC but they are currently Not able to connect to my AzBox Premium Plus - when they did before!! May have to look into a better Router ie Dlink, or Linksys?
  5. #4
    Join Date
    Aug 2nd, 2009
    Location
    42N 103W
    Posts
    1,283
    Post Thanks / Like
    I hope that you're not using WEP because it can be easily hacked. You should be using WPA2 instead. Anyway, the passphrase for the encryption key is case sensitive. If you're saying that you turned off the wireless encryption and the Azbox works OK then you're probably using the wrong wireless encryption passphrase. The Azbox won't draw a DHCP provided address if the encryption key isn't set right. If the passphrase isn't right, setting a static IP in the Azbox won't matter. Until the passphrase is correct you won't be able to associate with the WAP (wireless access point) on your router and that means you won't be able to connect to the LAN (intranet) or to the WAN (internet).
    Azbox Elite and Ultra (both 5402 firmware), 4DTV DSR922/HDD-200 (non-bricked 4160 EMM), Paraclipse-12 with C2, KTI CKD-12 w/DMX741, WS9036/DMX521/SG9120, Sony Bravia 46", Sony BluRay models BDP-S360 and BDP-S570, Onkyo 6.1 Amplifier, D-Link MovieNite, too many remote controls.
  6. #5
    Join Date
    Jul 4th, 2006
    Posts
    1,032
    Post Thanks / Like
    Thread Starter
    Get Rid of this Ad! Register Today!
    Quote Originally Posted by johnnynobody View Post
    Thanks for the valuable info Johnnynobody.
  7. #6
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! Cham did! Help Support The Site And Get Rid of the Syndicated Ads, Cham did! If you enjoy the site consider supporting it, Cham did! Be COOL like Cham and Click a Star and become a Supporting Pub Member today!
    Join Date
    Dec 19th, 2008
    Location
    N49d 1.8' W96d 2.6' SE Manitoba
    Posts
    668
    Post Thanks / Like
    ADVERTISING BOX
    Maybe try connecting using the 10/100 ethernet hard wire connection. If you get that working then go back to wireless.
    Been using an Asus RT-N16 router with DD-WRT firmware but I don't bother with the wireless, way too slow for me. Wish they had gigabyte ethernet on these receivers though... No issues that way with security.
    AzBox Ultra, 10' bud, C2 LNBF,WSI-9036, SG2100 with SNH-031
    MicroHD, 36" no name dish (and sharing C2 above), SG9120B, SP1PLL
    + various dishes, LNBs and receivers
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
