Quantcast
722 has higher signal than 622?
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Page 1 of 2 12 LastLast
Results 1 to 6 of 7
  1. #1
    Join Date
    Oct 5th, 2004
    Location
    Haiti and lexington ky
    Posts
    318
    Post Thanks / Like
    Hey guys, i have a 722 and a 622. i noticed my 722 started displaying pixelated images due to poor signal , but when i look at the signal meter on the 622 the signal is high and it does not pixel.
    I swapped boxes with the different runs, but its the same problem. the software on the 722 is L724.
    thanks
    ***** By the way the 622 has a higher signal than the 722******
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
  3. #2
    Join Date
    Sep 29th, 2005
    Location
    Greentown, Pennsylvania, United States
    Posts
    7,175
    Post Thanks / Like
    How much difference is the signal strength on the same transponder and how did it change on both receivers when you switched locations? I'd also use the transponder for the channel you are having the problem with.
  4. #3
    Join Date
    Oct 5th, 2004
    Location
    Posts
    318
    Post Thanks / Like
    Thread Starter
    on the 722 i get 25 and on 622 i get 40
  5. #4
    Join Date
    Sep 29th, 2005
    Location
    Posts
    7,175
    Post Thanks / Like
    Which transponder? It's not a spot beam is it? 40 is slightly low, 25 is too low, any slight drop on 25 would cause your pixelation. It may only need a slight adjustment.
  6. #5
    Join Date
    Oct 5th, 2004
    Location
    Posts
    318
    Post Thanks / Like
    Thread Starter
    Get Rid of this Ad! Register Today!
    but its just the 722 that has signal issues. if i switch the 722 to where the 622 is its the same problem. I thought at first that my coax was going bad, but thats not the case.
  7. #6
    Join Date
    Sep 29th, 2005
    Location
    Posts
    7,175
    Post Thanks / Like
    ADVERTISING BOX
    It is easier to troubleshoot when complete info is given. If the problem follows the receiver, it is probably the receiver but something else could be the problem. Are you using DPP equipment? If so, when you changed the receiver's, did you move the separator with the receiver or change at the wires directly connected to the 722? If the separator was moved with receiver, switch it to the 622 and see if problem moves too. If it does, you may have a bad separator, if not, it is probably the 722.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
