Quantcast
2 hoppers off a single tap, OK?
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Page 5 of 5 FirstFirst ... 345
Results 25 to 30 of 30
  1. #25
    Join Date
    Feb 5th, 2012
    Location
    United States
    Posts
    75
    Post Thanks / Like
    Thread Starter
    Quote Originally Posted by hdqboss View Post
    Only one Hopper should be connected to an Ethernet. Connecting both Hoppers will cause you problems. Disconnect one Hooper and reboot your system and your Joeys should show as connected.
    I tried that still it did not work. It might have to do with how the system is wired. The Joeys are coming off a splitter that is fed by the client output of a tap so
    Tap
    Host----Hopper1
    Client----Splitter
    Splitter
    Output1-----Joey1
    Output2-----Joey2
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
  3. #26
    Join Date
    Feb 5th, 2012
    Location
    United States
    Posts
    75
    Post Thanks / Like
    Thread Starter
    Quote Originally Posted by sparc View Post
    what's not working on the joey? are able to access ondemand? are you able to access the apps?
    The Joeys can access Apps just fine. I have not tried OnDemand. Yet, the network settings show the red "Failed" for the broadband connectivity instead of OK, which is puzzling me.
  4. #27
    Join Date
    Feb 5th, 2012
    Location
    United States
    Posts
    75
    Post Thanks / Like
    Thread Starter
    Problem solved.
    It was all about bridging. It was disabled by default. Now, one Hopper is connected to Ethernet; that is it. I had to enable bridging.
  5. #28
    Join Date
    Feb 5th, 2012
    Location
    United States
    Posts
    75
    Post Thanks / Like
    Thread Starter
    Quote Originally Posted by sperry85 View Post
    A dish pro plus 500+ lnb has the switch built inside. The lnb picks up 119 118.7 and 110 orbitals. It has 3 outputs for receivers and 1 input that you would run the dp single to for the 129 orbital.
    I have the tech and he is replacing the antenna to DPP500+ but he is saying I still need the DP44 since the duo node only takes 3 inputs. I have international so I need all 4 Sats. Is there anyway to connect DPP500+ to duo node directly and still get all 4 Sats?
  6. #29
    Join Date
    Aug 9th, 2011
    Posts
    162
    Post Thanks / Like
    Get Rid of this Ad! Register Today!
    Quote Originally Posted by CCTX
    A dish pro plus 500+ lnb has 4 ports on it. 3 are outputs, 1 is input for another orbital. You run a small jumper from the dp single to the 500+ input port. Then you run 3 wires from the 3 outputs to the duo node. The dpp500+ has the switch built inside the lnb.
    Get rid of this ad below, as well as the link redirect by becoming a Supporting Pub Member
  7. #30
    Join Date
    Feb 5th, 2012
    Location
    United States
    Posts
    75
    Post Thanks / Like
    Thread Starter
    ADVERTISING BOX
    Thank you so much. Unfortunately, it was a little late. He already left. What a great forum full of knowledgeable people! By the way, he was a supervisor and he had the QC person with him and both did not know.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
