Results 1 to 4 of 4
Thread: Can't get channel 2 WBBM Chicago
  1. #1
    Join Date
    Feb 4th, 2005
    Posts
    7
    Post Thanks / Like
    I can't get channel 2 Chicago .We tried every direction all other stations are fine.Channel 2 I am told is a VHF station. They installed a square shooter ant.Can anyone help I talked to VOOM and they gave me the ok but the installer say's the only antenna that may work is 8 feet long.Can I install a inside antenna myself or does anyone from Chicago have any ideas I live in Homer Glen,IL..Thank You
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Posts
    Many
    Reigster at SatelliteGuys
  3. #2
    Join Date
    Jan 20th, 2004
    Posts
    376
    Post Thanks / Like
    I think the square shooter is UHF only. Is channel 2 the digital channel or do they broadcast the digital signal for analog channel 2 on a different RF? Check antennaweb.org to find out the correct RF. If the RF is channel 2 then you will need a VHF antenna that will be about 8 feet long. In NYC where I am, only one digital channel was broadcasting on a VHF and that was on RF channel 12 which is the shortest "arm" on a VHF antenna but it is still about 3 ft. If you find out that you only need to pick up one VHF channel and not all the VHFs that are broadcasting analog then you can look for a "cut antenna" which is an antenna designed to pick up only one VHF channel.
  4. #3
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! philhu did! Help Support The Site And Get Rid of the Syndicated Ads, philhu did! If you enjoy the site consider supporting it, philhu did! Be COOL like philhu and Click a Star and become a Supporting Pub Member today!
    Join Date
    Sep 1st, 2004
    Location
    Cold Boston Area
    Posts
    1,215
    Post Thanks / Like
    antennacentral.com has a vhf wbbm special antenna for chicago people
  5. #4
    Join Date
    Feb 4th, 2005
    Posts
    7
    Post Thanks / Like
    Thread Starter
    Thank You
    Thanks I'm Going To Try To Get The Install Approved For A V4 Mkii With A Uhf/vhf Combiner.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
