Results 1 to 6 of 10
Thread: 45.5 to 61 C band
08-04-2012 09:35 AM #1
45.5 to 61 C band
Are there any channels that are on any satellites between 45.5 and 61 C band that a FTA system can receive? I've never found anything on any of those satellites not even the signal to actually find the satellite. I do have a clear line of site to all of them. Anything worth trying to find?
Warning: This is an Old Thread
This discussion is older than 90 days. information contained in it may no longer be current
08-04-2012 09:35 AM # ADS
Register Today & This Ad Goes Away! Syndicated Advertisement- Join Date
- Always
- Location
- Advertising world
- Posts
- Many
08-04-2012 09:38 AM #2
There is a bunch of ITC stuff on 58W C-band. A lot of it is in Spanish, but quite a bit of English-speaking also. A lot of the channels can be found elsewhere on the arc in either C or Ku-band
I was going to ask the same question of what is east of 58W last week, will be interested to see what kind of replies you get here.C-Band: 12' Unimesh/AJAK 180/GeoSat C2***10' "Perfect 10" mesh/GeoSat C2*** 8.5' Birdview solid/BV H-H/GeoSat C2*** 7.5' Unimesh/CalAmp voltage-controlled LNBF***...C-Band LOS from 58W-139W
Ku-Band: 3ABN .9m/SL1PLL LNBF/SG2100***Fortec .9m/TrackerII LNBF/STAB HH90***7.25' Birdview "Spoon"/TrackerII/70:1 BV H-H***Prodelin 1.8m/GeoSat Bullet/AJAK 180 H-H***Paraclipse Hydro 1.5m Prime Focus/Linear Actuator/C120 LNBF...Ku-Band LOS from 30W-129W
Receivers: Toshiba TRX-1820 Analog-->AZBox Elite/Openbox S9 HDx2***GeosatPro microHD
OTA Digital: CM 4228/CM 7777 Preamp/Apex DT-250 for OTA Locals, Toshiba 46" Regza & Toshiba 19" LCDs
In Progress: (2) Birdview 8.5' (1 solid & 1 perf) w/Birdview H-H mounts, "Drake" 10' solid alum....*BVOC Asst. Cook & Bottlewasher*
08-04-2012 09:47 AM #3
- Join Date
- Jun 22nd, 2005
- Location
- West Virginia
- Posts
- 742
- Post Thanks / Like
- Thread Starter
Thanks. In Spanish would be perfect.
Not that I can understand it yet but if I keep watching it I'll figure it out maybe.
08-04-2012 09:51 AM #4
The signals seem to be pretty strong here, from that sat, on most of the tps
I can't see 58W with my only BUD that is cabled into the house, but in the last 2 weeks I have went outside and hooked up my 8.5' Birdview solid and my 7.5' Unimesh mesh dishes, both worked well on 58W.
I think the signals start getting scarcer once you go east of 58W, hopefully someone will tell us different.C-Band: 12' Unimesh/AJAK 180/GeoSat C2***10' "Perfect 10" mesh/GeoSat C2*** 8.5' Birdview solid/BV H-H/GeoSat C2*** 7.5' Unimesh/CalAmp voltage-controlled LNBF***...C-Band LOS from 58W-139W
08-04-2012 01:41 PM #5
There are plenty of signals east of 58w. Many however are circular polarity instead of linear, but not all.
Network muxes tend to be encrypted, of course. Lots of what I might call ethnic channels, meant for South/Central America, Africa, and the Middle East.
There is one English channel on NSS10 @ 37.5w called Metro which is out of Ghana IIRC. had a soccer match on it the last I looked months ago. But that's as far east as I can receive with a linear only feed. I can see signals on the SA as far as 22w with my actuator on the west side of the dish mount.
08-05-2012 01:28 AM #6
- Join Date
- Jun 22nd, 2005
- Location
- West Virginia
- Posts
- 742
- Thread Starter
I'm only using a 6 footer would that make a difference in finding the signals? I am not using circular right now.
ADVERTISING BOX
Register To Reply
