Quantcast
hello i how are you guys i need help with a 6 foot c band dish i will discribe bellow what i need to do
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Page 3 of 5 FirstFirst 12345 LastLast
Results 13 to 18 of 30
  1. #13
    Join Date
    May 23rd, 2008
    Posts
    676
    Post Thanks / Like
    You can't conclude that you got bad products yet.
    On the positive side, if you can potentially grab 137, that is 65 degrees west of your longitude. That should mean you can go way down to less than ten degrees west. There are a lot of satellites in that arc.
    Check your wiring.Check your actuator and especially make sure its on there straight. Oil up your dish mechanism. Reset your mover.
    Looks to me, whatever side you put your actuator on, when the dish is on 72 west, it should be right in the dead center of the throw.
    Stay patient. You'll be happy in the end.
  2. #14
    Join Date
    Aug 20th, 2006
    Location
    Rison , Arkansas
    Posts
    3,628
    Post Thanks / Like
    another limitation and i didn't think of it earlier but fond it metioned in another thread once you get to 72 from 40 east side mount , some have mentioned a limitation from the dish mount itself , so make sure the motor arm isn't getting into a bind on the dish mount as it gets close to 72
  3. #15
    Join Date
    Jan 8th, 2012
    Location
    NC, USA
    Posts
    308
    Post Thanks / Like
    I have a V-Box that came with an remote control and I can use the remote to go passed the set satellite position, I do not know if the G-box can do the same. Currently I do not have any limit set in my v-box nor my receiver.
    But, ..... You can check if the actuator itself is at fault. Remember that the actuator itself could have limits set and I do not know anything about this actuator.
    You could turn off the power and unplug your G-box and receiver. Leave the G- Box and receiver disconnected all the time while doing this.
    Then disconnect the motor leads that is coming from your G-Box on the actuator.
    Connect 2 wires to the actuator on the motor terminal, MAKING SURE THAT YOU DO NOT CONNECT THESES 2 WIRES TO THE REED SWITCH TERMINAL and then connect the wires to a 12 volt or 24 volt ( 2 12 volt batteries in series) to a battery.
    To reverse the travel of your actuator just reverse the polarity of the 2 wires.
    Do this at the dish so you can see what is going on, and if there is a bind or a stop disconnect the battery right away and see what the cause is.
    I used a double pole - double throw momentary switch with center position of the switch OFF a while back to aim and adjust my dish, this way I was able to stop the dish with the switch and I was able to change directions without having to disconnect the wires from the battery or actuator. I took the receiver, cheap signal meter and a TV to the dish and hooked it straight to the dish without my V-box so I can match the dish to the arc.
    Here is a wire-diagram. Click image for larger version.
    Here are some pictures.Click image for larger version.
ID:	80088Click image for larger version.
    My first free dish, 7.5 feet K-tronicsClick image for larger version.
  4. #16
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! FaT Air did! Help Support The Site And Get Rid of the Syndicated Ads, FaT Air did! If you enjoy the site consider supporting it, FaT Air did! Be COOL like FaT Air and Click a Star and become a Supporting Pub Member today!
    Join Date
    Feb 27th, 2010
    Location
    97W 48N
    Posts
    3,258
    Post Thanks / Like
    Bri40, measure the length of the extended portion of your actuator. If it's not close to the 'advertised' 24 inches, I suspect that the internal limit switch is stopping it from extending more. Open it up and take a 'look see'.
    Or it could also be the limits set in the GBox.
    Ref: my actuator at 55W and then at 137W
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	80090   Click image for larger version.
ID:	80091   Click image for larger version.
    One night I walked home very late and fell asleep in somebody's satellite dish.My dreams were showing up on TV's all over the world. -- Steven Wright
    Openbox S9, Pansat 3500SD, 139w to 55.5W +30W
    10Ft USS Steel BUD and an assortment of P
    dishes, 84e(1), .7m(2), 1.2m(2). 2.4m[8ft](1) offset in storage. 🐱
  5. #17
    Join Date
    Jan 8th, 2012
    Location
    NC, USA
    Posts
    308
    Post Thanks / Like
    Quote Originally Posted by FaT Air View Post
    I am confused where exactly you measure the distance.
    Does the measurement stop at the boot etc ?
    Thanks Fat Air.
  6. #18
    Join Date
    Jan 8th, 2012
    Location
    NC, USA
    Posts
    308
    Post Thanks / Like
    ADVERTISING BOX
    You stated here that you have a limit set on the receiver.
    The receiver will control the G-Box. So if you have a limit set on the receiver, the receiver will tell the G-Box that a limit is set and will stop at the limit set by the receiver.
    Undo you limit at the receiver and see what happen.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
