Quantcast
Channels on new Satellite
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Page 3 of 4 FirstFirst 1234 LastLast
Results 13 to 18 of 20
  1. #13
    Join Date
    Jul 19th, 2012
    Location
    Lancaster, PA
    Posts
    17
    Post Thanks / Like
    Thread Starter
    Alright, I'm going to try to stick with Bell. So I got a 9241 receiver, set it up with a DPP twin LNB and separator. I'm getting signal from 82W on both inputs when I run a check switch (per my previous posts, 91W is not an option). However, when it goes to download information, all I get is "Acquiring Satellite...". Left it at that screen for 30+ minutes with no change. Any ideas?
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
  3. #14
    Join Date
    Jul 19th, 2012
    Location
    Lancaster, PA
    Posts
    17
    Post Thanks / Like
    Thread Starter
    An update. My satellite guy was here today trying things out. The strange thing is that he gets the dish pointed, it shows up on the "point dish" screen as 82W, but then when I run a check switch, the satellite shows up as 72W or 77W. Literally, I ran check switch once and it showed 72, then without changing anything, ran another check switch and it showed as 77. Has anyone seen this before? It's getting frustrating. I should be able to just have 82W without 91W shouldn't I?
  4. #15
    Join Date
    Apr 15th, 2007
    Posts
    286
    Post Thanks / Like
    Sounds to me like your Dish is not aimed correctly.
    Try aiming with a Legacy LNBF in the 82 slot of the "Y" yolk. When you get that peaked (Don't forget to set the skew first), add the DPP Twin and then run the Check Switch.
  5. #16
    Join Date
    Jul 19th, 2012
    Location
    Lancaster, PA
    Posts
    17
    Post Thanks / Like
    Thread Starter
    So I should be able to use the dish pointer on my old 3100 receiver to at least verify reception?
  6. #17
    Join Date
    Apr 15th, 2007
    Posts
    286
    Post Thanks / Like
    Get Rid of this Ad! Register Today!
    Yes but not all Transponders will show on a SD Receiver aimed at 82, so aim at 91 with the LNBF in the 91 slot of the "Y" yolk. Then use TP's 1 & 32, I am pretty sure they work on the SD box.
  7. #18
    Join Date
    Jul 19th, 2012
    Location
    Lancaster, PA
    Posts
    17
    Post Thanks / Like
    Thread Starter
    ADVERTISING BOX
    Still having issues and getting a little frustrated. I have some questions regarding getting my BellTV working in the US now that I'm outside the 91W footprint.
    First, my setup:
    Standard 20" dish
    DPP LNB (have also tried the Dish LNB)
    9241 Receiver
    Locked onto 82W at ~50% signal on most transponders. When I go to the next screen it sits at "Acquiring Satellite.." and does not progress.
    I wonder if someone can answer authoritatively:
    1. Should I be able to receive programming by hitting 82W exclusively and not 91W?
    2. Am I using the wrong LNB?
    3. Do I need a bigger dish, or is 50% signal adequate?
    4. Could this happen if there is a problem with the way I activated my receiver? It shows activated on the website, but I don't want to call Bell if I don't have to.
    Any help would be appreciated.
    Thanks!
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
