Quantcast
C-Band Orthomode setup, seperate KU dish and DisEqc motor and the microHD receiver.
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Page 1 of 5 123 ... LastLast
Results 1 to 6 of 27
  1. #1
    Join Date
    Mar 15th, 2005
    Location
    Michigan
    Posts
    2,018
    Post Thanks / Like
    Well, I'm going to go to an orthomode setup on my Sadoun 6 foot dish with microHD receiver.
    I have a Chaparral 11-1329-1 Dual C-Band Feed Horn, a pair of Norsat 8115 C-Band LNB's, and a MS4x8WB-WNC switch on the way.
    It sounds like after you mod the switch for 18v, you can use an extra coax cable to run power to the switch from the house. Then since at the moment I'm only using the single microHD receiver, I only need a single coax run for that.
    One question is how the microHD receiver would then be set to select either horizontal or vertical transponders on the seperate lnb's? If the switch is modded to always pass 18 volts, how can it switch back and forth between them? Maybe I'm over-thinking this? Is it just that the receiver still uses 13v and 18v, and is "fooled" because the switch now does the "thinking" and still selects the former 13volt input OR old 18volt input depending on the receiver as needed?
    Also, since I have a seperate KU dish with a DisEqc motor on it, how would that all wire in with this new ortho setup? Can I use one of the other 2 lnb inputs on the MS4x8WB-WNC switch to select the KU lnb, thus eliminating the DisEqc switch that's there now?
    Right now, I have the coax going to the DisEqc motor input. On the output of the motor, I have a DisEqc switch. Port 1 goes to the C-band (Geosatpro C2 lnbf for now) and Port 2 goes to the KU lnb. It all works fine, and motor moves, etc. I'll also have a Powermax V-Box X installed to run the c-band dish actuator before this is all through, so that also (I'd prefer if it did anyway) has to go inline with the coax going out to the dishes.
    Thanks for any input into this!
    Warning: This is an Old Thread
    This discussion is older than 90 days. information contained in it may no longer be current
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
  3. #2
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! Magic Static did! Help Support The Site And Get Rid of the Syndicated Ads, Magic Static did! If you enjoy the site consider supporting it, Magic Static did! Be COOL like Magic Static and Click a Star and become a Supporting Pub Member today!
    Join Date
    Oct 12th, 2010
    Location
    46°51'20.67"N 114°01'50.57"W Montana
    Posts
    1,847
    Post Thanks / Like
    The switch still responds to the voltage switching from the receiver and selects the correct LNB. It's just now providing full power to all LNBs now.
    10'Winegard.Pinnacle.perforated, AJAK 180 H-H, GBox, BullsEyeII-Norsat-8115,4106a
    GEOSATProMicroHD,WD-TV_LiveHub,SlingBoxProHD
    9.5'Laser.C/Ku.mesh, 24"VonWeise, V-Box-X,BullseyeII-Norsat_3220,1208HA
    MyTheatre on , 2 NEC LT30 DLP projectors, 52" Samsung, 25.5"ASUS
    ASUS Maximus Formula III, Corei7 Quad 2.8 OC 3.66, 3.4g FSB ,16g DDR316000
    (2) Nvidia GForce 9800GT PCIe, 240g SSD, 4TB storage.
  4. #3
    Join Date
    Oct 12th, 2010
    Location
    Posts
    1,847
    Post Thanks / Like
    I use an 1X8 to connect both the VBox and SG2100 to the receiver
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  5. #4
    Join Date
    Feb 27th, 2010
    Location
    Traverse City, Michigan
    Posts
    1,637
    Post Thanks / Like
    You are to inject 18-24v. into the modified switch from an external supply. I used a 19v. lap top power pack. The Micro set up is the same as your LNBF, 13v for vert, 18v for horz. The WNC switch will read the voltage and switch in the appropriate lnb. The coax voltage never gets to the LNBs as they are now powered by the external supply.
  6. #5
    Join Date
    Mar 15th, 2005
    Location
    Michigan
    Posts
    2,018
    Post Thanks / Like
    Thread Starter
    Get Rid of this Ad! Register Today!
    Quote Originally Posted by Magic Static View Post
    So you are running a 1x8 DisEqc switch off the back of your receiver, and it's still capable of controlling TWO KU motorized dishes, and still selecting from any lnb on the c-band dish to both ku band dishes without issues? Does a 1x8 switch work different then a 1x4 DisEqc switch? I didn't think they could pass enough current for motors.
  7. #6
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! brentb636 did! Help Support The Site And Get Rid of the Syndicated Ads, brentb636 did! If you enjoy the site consider supporting it, brentb636 did! Be COOL like brentb636 and Click a Star and become a Supporting Pub Member today!
    Join Date
    Jun 24th, 2006
    Location
    5 miles N of Saugatuck, Mi
    Posts
    4,270
    Post Thanks / Like
    ADVERTISING BOX
    If you only modify 1 side of the WNC 4x8 switch, then you can use the other ( 22khz ON, for example) to handle a dual output Ku lnbf, thus putting both the C-band and Ku band on the same switch with 8 receiver outputs.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
