Quantcast
Where to put inline amlifier
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Welcome HOME to SatelliteGuys! We are America's Most Popular Satellite Forum!
Page 4 of 4 FirstFirst ... 234
Results 19 to 22 of 22
  1. #19
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! FaT Air did! Help Support The Site And Get Rid of the Syndicated Ads, FaT Air did! If you enjoy the site consider supporting it, FaT Air did! Be COOL like FaT Air and Click a Star and become a Supporting Pub Member today!
    Join Date
    Feb 27th, 2010
    Location
    97W 48N
    Posts
    3,137
    Post Thanks / Like
    Many different answers to different scenarios, the symptoms are really unknown here.
    But here's a stab at some probable symptoms:
    With the receiver close to the dish it receives the channels desired and at the other end of the long coax run they are not coming in, an amplifier may help.
    If you can't receive the channels desired when the receiver is connected to the dish/switch/lnbf's with a short coax, an amplifier will not help. Only a bigger dish will help in this instance.
    A 50 meter run of good quality coax should not require the use of an amplifier. I would venture to say that there's excessive loss in your switch. (good RG6 at that length would not have excessive loss) Test by bypassing the switch. If that's it, replace with a better switch.
    If most satellites perform well presently but one is problematic, think a separate larger fixed dish is the answer.
    One night I walked home very late and fell asleep in somebody's satellite dish.My dreams were showing up on TV's all over the world. -- Steven Wright
    Openbox S9, Pansat 3500SD, 139w to 55.5W +30W
    10Ft USS Steel BUD and an assortment of P
    dishes, 84e(1), .7m(2), 1.2m(2). 2.4m[8ft](1) offset in storage. 🐱
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
  3. #20
    Join Date
    Aug 21st, 2012
    Location
    BIH
    Posts
    6
    Post Thanks / Like
    Thread Starter
    Quote Originally Posted by SatelliteAV View Post
    Where are you located and what satellites are you trying to receive?
    Why do you feel that your system needs online amplifiers?
    Personally, I would first purchase a quality amplified switch and possibly consider upgrading the coax to a quad shield RG6. 50M is not that long of cable run and will not likely benefit from inline amps.
    The dish looks to be of good quality, but be aware that the performance of this design is lower than a similar sized dish designed for single satellite reception. It is a neat idea, but with reduced performance.
    Which switch do you recommend?
    I am in Bosnia, and I am aiming for ASTRA satellite's on 19.2 E, EUTELSAT on 16.0 E, HOT BIRD 13.0 E and ARABSAT on 20.0E for the begining.
  4. #21
    Join Date
    Aug 21st, 2012
    Location
    BIH
    Posts
    6
    Post Thanks / Like
    Thread Starter
    I have just double checked and my cable is 2YCFGY. How this cable compares with RG6?
  5. #22
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! lost_mesa did! Help Support The Site And Get Rid of the Syndicated Ads, lost_mesa did! If you enjoy the site consider supporting it, lost_mesa did! Be COOL like lost_mesa and Click a Star and become a Supporting Pub Member today!
    Join Date
    Oct 18th, 2010
    Location
    New Mexico
    Posts
    25
    Post Thanks / Like
    ADVERTISING BOX
    I Googled 2YCFGY coax and found a loss of 27 db per 100 meters at 850 MHz. It didn't list the loss at higher frequencies, but the loss will be much higher in the 950 to 2150 MHz range that you are using.
    This loss is higher than even RG59. At 850 MHz RG59 is about 25 db per 100 meters and RG6 is about 20 db.
    Can you move your receiver to the dish and test it there with a short piece of RG6 cable? If that works OK, then better cable is probably your answer.
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
