Results 13 to 18 of 38
Thread: Circular Ku Channels
08-25-2012 08:51 AM #13
Direct connect to the "C" output of the LNBF. Set the STB LO to 11250. Blindscan 82w, 91w,110w, 119w, etc. You will find circular transponders with frequencies between 12200 and 12750mhz.
The QPH-031 LNBFs have very tight frequency drop off on the Circular and Linear outputs. Since these outputs are hardwired to the respective polarity circuits, there will be very little portion of the other frequency range that could be logged. You might scan a few frequencies below 12200 on the "C" output and a few frequencies above 12200 on the "L" output. The reception of linear with the circular circuits and circular with the linear circuits is possible, but the signals are attenuated by approximately 3dB (each 3dB is a doubling of power). You will see some transponders from the opposite polarity, but they will be much weaker!
Satellite AV, LLC (Gold Sponsor)
Equipment Development / Distribution / Repair / Call Center
888-483-4673 - http://www.satelliteav.com
eBay Special Deals
Attention Installers: Want more work? Join the Largest Satellite Technician Referral Website - www.FTAinstall.com
08-25-2012 08:51 AM # ADS
Register Today & This Ad Goes Away! Syndicated Advertisement- Join Date
- Always
- Location
- Advertising world
- Posts
- Many
08-25-2012 09:18 AM #14
One other important note. Most of the transponders on the DSS sats use a modulation your receiver can't do, 8PSK with Turbo FEC, most commonly refered to as Turbo 8PSK. Rarely, hidden channels will show in the clear for a short time, but for the most part there is nothing there to watch.
Iceberg provided the coordinates for Channel 101 on Dish119. That is like the only ITC channel to use for testing the LNBF.10'Winegard.Pinnacle.perforated, AJAK 180 H-H, GBox, BullsEyeII-Norsat-8115,4106a
GEOSATProMicroHD,WD-TV_LiveHub,SlingBoxProHD
9.5'Laser.C/Ku.mesh, 24"VonWeise, V-Box-X,BullseyeII-Norsat_3220,1208HA
MyTheatre on , 2 NEC LT30 DLP projectors, 52" Samsung, 25.5"ASUS
ASUS Maximus Formula III, Corei7 Quad 2.8 OC 3.66, 3.4g FSB ,16g DDR316000
(2) Nvidia GForce 9800GT PCIe, 240g SSD, 4TB storage.
08-26-2012 02:25 PM #15
Hey MagicStatic,hope you be fine there.Question: When we remove the dielectric plate from a 621 lnbf we are looking for linear polarity.So we are not able to lock circular polarity.Does that work on C band only or does it affect KU band also?
08-26-2012 03:53 PM #16
The dielectric plate in the C/KU is only for C-band. C/KU LNBFs do not receive circular KU-band( with or without the dielectric slab).
eBay Special Deals
08-26-2012 04:46 PM #17
Why is that? Never gave it much thought but I had (incorrectly) assumed the slab would convert the feed to circular reception in both bands.
C-Band: 12' Unimesh/AJAK 180/GeoSat C2***10' "Perfect 10" mesh/GeoSat C2*** 8.5' Birdview solid/BV H-H/GeoSat C2*** 7.5' Unimesh/CalAmp voltage-controlled LNBF***...C-Band LOS from 58W-139W
Ku-Band: 3ABN .9m/SL1PLL LNBF/SG2100***Fortec .9m/TrackerII LNBF/STAB HH90***7.25' Birdview "Spoon"/TrackerII/70:1 BV H-H***Prodelin 1.8m/GeoSat Bullet/AJAK 180 H-H***Paraclipse Hydro 1.5m Prime Focus/Linear Actuator/C120 LNBF...Ku-Band LOS from 30W-129W
Receivers: Toshiba TRX-1820 Analog-->AZBox Elite/Openbox S9 HDx2***GeosatPro microHD
OTA Digital: CM 4228/CM 7777 Preamp/Apex DT-250 for OTA Locals, Toshiba 46" Regza & Toshiba 19" LCDs
In Progress: (2) Birdview 8.5' (1 solid & 1 perf) w/Birdview H-H mounts, "Drake" 10' solid alum....*BVOC Asst. Cook & Bottlewasher*
08-26-2012 05:15 PM #18Satellite AV, LLC (Gold Sponsor)
eBay Special Deals
Register To Reply
