Quantcast
Please help
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Page 1 of 3 123 LastLast
Results 1 to 6 of 13
Thread: Please help
  1. #1
    Join Date
    Aug 24th, 2012
    Location
    Port Huron mi
    Posts
    Post Thanks / Like
    Please help
    so 6 months ago we moved out to the country, where we had to get dish, as cable was not an option. The installer told me I could take a receiver 50 miles north to my cabin to use, if I wanted, when I asked him, well he told me I would have to do a check switch, and so on. Well here's issue at home I have a HD dish satellite, with 2 boxes, that each feed 2 tv's, but the house I bought had a dish 500 satellite. What steps do I need to take step by step in order to get cable at my cabin? Now understand I go to my cabin maybe once a month, for a day, so I'm not trying to get over on dish. Please and thank you for the help
    Tom
    Warning: This is an Old Thread
    This discussion is older than 90 days. information contained in it may no longer be current
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
  3. #2
    Join Date
    Sep 4th, 2004
    Location
    Broken Arrow, Oklahoma
    Posts
    4,261
    Post Thanks / Like
    Take your receiver to the cabin, plug in wire from Dish to back of receiver where it says Sat in. Plug receiver into tv, power on receiver, select menu button and press 6,1,1 on Dish remote, then select check switch. Let it run the check and select save and then back your way out of the menus. The receiver will download a new guide for the different Dish setup. Be aware you will not get the HD channels on 129, since you are using a Dish 500.
    When you return to your main home, repeat the above steps for the Dish 1000.
  4. #3
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! gokartergo did! Help Support The Site And Get Rid of the Syndicated Ads, gokartergo did! If you enjoy the site consider supporting it, gokartergo did! Be COOL like gokartergo and Click a Star and become a Supporting Pub Member today!
    Join Date
    Jun 28th, 2010
    Location
    Ca
    Posts
    836
    Post Thanks / Like
    After the check switch a big box will appear.. Its says you have fewer satellites are you sure you want to save press yes and it will ask you again and still say yes.. The only thing you will be missing are some HD channels.. But you should still have all channels..
    2=Hoppers 2= EHD AND Google TV
    3= Joeys
  5. #4
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! boba did! Help Support The Site And Get Rid of the Syndicated Ads, boba did! If you enjoy the site consider supporting it, boba did! Be COOL like boba and Click a Star and become a Supporting Pub Member today!
    Join Date
    Dec 12th, 2003
    Location
    Dorchester, TX.
    Posts
    8,276
    Post Thanks / Like
    The home receivers are dual tuners and probably have separators, the dish 500 will probably need 2 lines run from the dish unless he is lucky enough to have a DPP Twin.
  6. #5
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! 3HaloODST did! Help Support The Site And Get Rid of the Syndicated Ads, 3HaloODST did! If you enjoy the site consider supporting it, 3HaloODST did! Be COOL like 3HaloODST and Click a Star and become a Supporting Pub Member today!
    Join Date
    Jul 2nd, 2010
    Location
    Earth
    Posts
    4,814
    Post Thanks / Like
    Get Rid of this Ad! Register Today!
    Quote Originally Posted by gokartergo View Post
    ... The only thing you will be missing are some HD channels.. ...
    More like almost all but a few... That being said you are correct.
    OP, if SD is all you need at the cabin, the 500 will be just fine.
    As boba said if it's not a DPP LNB (will have DP Plus logo on LNB if it is) then you will need a line for each tuner.
    2 Hoppers w/Sling / 2 Hopper 2000s / 1 Joey
    1 ViP722k (separate account)
  7. #6
    Join Date
    Aug 24th, 2012
    Location
    Port Huron mi
    Posts
    Post Thanks / Like
    Thread Starter
    More help please
    ADVERTISING BOX
    So I was trying the 611 and do check switch but I was still having issues? I have it set exactly the same as my neighbors-it's level facing 227 degrees on compass, 110, and 30 on dial settings. But I. Keep getting error codes. I had a DP triplexes hooked to back of receiver so I removed but only had 1 cable coming from sat, it was to the 119 eye, so I added another cable to 110, and ran the 110 to sat 1 in, and 119 to sat 2 in, then even swapped the 1 & 2, and nothing. Here are some error messages
    Reception error
    problem with connections
    one of the satellite inputs or switches is not connected properly, normal operation will be adversely affected
    On my point dish menu I put in zip, chose dish 500, tuner 1' and tried sat 110, then 119, what transponder should I choose?
    God please help, it is very appreciated
    Tom
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
