Results 1 to 6 of 18
08-27-2012 02:05 PM #1
Multiple tv setup with a motorized dish
Am about to cut ties to direct tv and want to know what I will need to setup a multiple tv fta setup I understand that I won't get what I had with directv ?
Warning: This is an Old Thread
This discussion is older than 90 days. information contained in it may no longer be current
08-27-2012 02:05 PM # ADS
Register Today & This Ad Goes Away! Syndicated Advertisement- Join Date
- Always
- Location
- Advertising world
- Posts
- Many
08-27-2012 05:45 PM #2
The most capable: Each television has independent channel selection. Receiver and dish/motor for each television. Second configuration: Multiswitch and a couple of fixed dishes with dual output LNBF's. Expand dish count with Diseqc switch. (covered in the FAQ section: Switches Simplified) (Maybe even motorize one?)
The least capable: modulator driven by receiver feeding all televisions. (All watch one 'channel') Think there's a reason enough for C band. Got room for an 8 - 10ft dish?
One night I walked home very late and fell asleep in somebody's satellite dish.My dreams were showing up on TV's all over the world. -- Steven Wright
Openbox S9, Pansat 3500SD, 139w to 55.5W +30W
10Ft USS Steel BUD and an assortment of P⭐ dishes, 84e(1), .7m(2), 1.2m(2). 2.4m[8ft](1) offset in storage. 🐱
08-27-2012 08:17 PM #3
- Join Date
- Jan 11th, 2005
- Location
- 32.750N 97.488W Fort worth Tx
- Posts
- 452
- Post Thanks / Like
- Thread Starter
It not necessary that each tv have independent channels as they all won't be watched at the same time can different tvs control the motor through a multiswitch
Originally Posted by FaT Air
08-28-2012 10:36 AM #4
- Join Date
- Jan 11th, 2005
- Location
- Posts
- 452
- Thread Starter
When i get the multiswitch how do i hook up a c/ku lnb to it
08-28-2012 11:11 AM #5
A multiswitch is usually to connect multiple LNBs to a single receiver (some multiswitches have multiple outputs).
A motor is best controlled by a single receiver.My dogs pepper & graci - for sale: this domain
dish: ViP622 DVR L711RBDD-N (BS1731), AT250HD+BB+Mobile/Pensacola, 1K4 EA
FTA: microHD, P* on SG2100(30W-123W-Ku), SuperDish on 125W-Ku, 39in ChannelMaster on 103W-Ku, Coolsat 7100 in closet
LG 55LW5300 3Dtv, Sony STR-DH520 7.1 AV, SlingBox classic, AppleTV2
08-28-2012 11:25 AM #6
ADVERTISING BOX
The receiver at one TV can control a motor as the motor is between the multiswitch and the receiver.can different tvs control the motor through a multiswitch
The other receivers are limited to the satellite that's selected by the one running the motor.
A dual band LNBF is not compatible with a multiswitch.multiswitch --- how do i hook up a c/ku lnb to it
A multiswitch allows multiple receivers to use any of the dual output LNBFs connected to it, independent of the other receivers. Dual output LNBFs are required so each receiver can get either polarity.
Connecting a 2nd receiver via the first receivers 'loop out' allows the 2nd receiver to receive channels on the satellite, polarity and band(C or Ku) that is selected by the first receiver, when using a dual band LNBF. (NO Multiswitch)Then, I would employ a modulator and combine with the OTA antenna and feed all TV's. IR remote Extenders employed to operate the satellite receiver.It not necessary that each tv have independent channels as they all won't be watched at the same timeOne night I walked home very late and fell asleep in somebody's satellite dish.My dreams were showing up on TV's all over the world. -- Steven Wright
Register To Reply
