Quantcast
Tuner hangs on interactive channel
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Welcome HOME to SatelliteGuys! We are America's Most Popular Satellite Forum!
Results 1 to 5 of 5
  1. #1
    Join Date
    Apr 29th, 2008
    Posts
    73
    Post Thanks / Like
    New problem just showed up on my 722K. When I scan through the channels, either up or down, I get stalled at the interactive channel. I can't go up, down or recall; the only way to proceed is to push "select", start the interactive download and then push recall. The receiver will return to the previous channel. My info screen says I am at L753 software. I have done a power down, pull plug, reboot but no change.
    anyone else have this problem?
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Posts
    Many
  3. #2
    Join Date
    Sep 29th, 2005
    Location
    Greentown, Pennsylvania, United States
    Posts
    7,175
    Post Thanks / Like
    I believe it is set to work like this. If you don't use the interactive channel, you can lock it out which should skip over the channel. I'm not sure if using favorites will work (it should but it is easily switched to different list).
  4. #3
    Join Date
    Apr 29th, 2008
    Posts
    73
    Post Thanks / Like
    Thread Starter
    That's not the way it has been working. When you scan into an interactive channel (95,96,100) you get a message (326) to either enter by pushing select or changing channels up or down with the remote arrows. This no longer works.
  5. #4
    Join Date
    Sep 10th, 2009
    Location
    HOCKEYTOWN
    Posts
    831
    Post Thanks / Like
    mine does the same bs....seems I can pass it going down but not up....never did it before the last firmware update that I know of...
    YOU DAMN RIGHT I GOT THE BLUES!!!!
    Trolling all day!!!!
    Bluegill Island
    Lobdell Lake
  6. #5
    Join Date
    Sep 10th, 2009
    Location
    HOCKEYTOWN
    Posts
    831
    Post Thanks / Like
    ADVERTISING BOX
    if mine does get stuck I usually go to the guide to get out of it....
    Bluegill Island
    Lobdell Lake
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
