Quantcast
Dish on a UK TV
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Page 1 of 2 12 LastLast
Results 1 to 6 of 12
Thread: Dish on a UK TV
  1. #1
    Join Date
    Sep 9th, 2012
    Location
    maine
    Posts
    Post Thanks / Like
    Dish on a UK TV
    OK, I arrived from the UK with 2 flat screen TVs (one a Panasonic TX-32LMD70) which are set to receive a PAL terrestrial signal. Just signed up to DISH but would like to use one of my not so old UK TVs to watch dish. I am assuming the output signal from my DISH box is NTSC. I have tried to tune one TV but only get a very grainy B&W signal on channel 60. Clearly the simplest answer is to get another US TV. But I would like to exhaust the potential of getting use out of my UK TVs. Any suggestions of how to do this? I have a DISH box set for 2 TVs and want to connect my UK TV onto the TV2 outlet. I have the aerial connector adapter to change US coax to UK coax
  2. #2
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! boba did! Help Support The Site And Get Rid of the Syndicated Ads, boba did! If you enjoy the site consider supporting it, boba did! Be COOL like boba and Click a Star and become a Supporting Pub Member today!
    Join Date
    Dec 12th, 2003
    Location
    Dorchester, TX.
    Posts
    8,377
    Post Thanks / Like
    Quote Originally Posted by quadruped View Post
    Sorry but your SOL PAL625 is not compatible with NTSC/ATSC broadcasts. That B&W picture is as good as it gets unless your TV is multi format which is doubtful.
  3. #3
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! Tampa8 did! Help Support The Site And Get Rid of the Syndicated Ads, Tampa8 did! If you enjoy the site consider supporting it, Tampa8 did! Be COOL like Tampa8 and Click a Star and become a Supporting Pub Member today!
    Join Date
    Sep 8th, 2003
    Location
    Tampa/Eastern Ct
    Posts
    6,299
    Post Thanks / Like
    I would think one of these should work?
    http://www.220-electronics.com/pal-ntsc-secam-video-converter.htm
    Get rid of this ad below, as well as the link redirect by becoming a Supporting Pub Member
  4. #4
    TNGTony's Avatar
    TNGTony is offline Proud Staff Member
    Proud SatelliteGuys Staff Member
    Proud Staff Member
    Join Date
    Sep 7th, 2003
    Location
    Cincinnati, Ohio, USA
    Posts
    7,482
    Post Thanks / Like
    There are NTSC/PAL/SECAM converters out there starting at about $100.
    http://www.world-import.com/samar.htm
    (NOT AN ENDORSEMENT) is the cheapest one I found that goes NTSC>PAL but it is definitely not HD. The HD converters out there are pretty pricey.
    THERE= a place. not here - THEIR= belongs to them - THEY'RE = short for "They Are". THEN = a point in time; not now. - THAN = used to compare things.
    -If you tried 4 times to move forward, it was the FOURTH time you went FORTH! ---Something AFFECTS you. You have an EFFECT on something
    Some one can win a MEDAL made of a METAL like gold for showing his METTLE (courage)
    If something is LOOSE you might LOSE it. Your=belongs to "you" You're short for "you are"
    You file a suit in court. You wear a suit in court. You stay in a suite at the hotel. You sweat it out. Victory is sweet!
    If two sets of twin brothers have a gunfight, you have a Dual Duel
    MUTE=Silent, unable to talk. MOOT= No longer relevant or important. "A mute points out a moot point."
  5. #5
    Join Date
    Sep 30th, 2006
    Location
    Great High Plains
    Posts
    8,660
    Post Thanks / Like
    You didn't say what type of Dish sat receiver you are trying to use. If it is a VIP then you may be able to use the HDMI input on the set. You will not be able to use the RF input w/o the adapters mentioned (PAL or NTSC).
  6. #6
    Join Date
    Sep 9th, 2012
    Location
    maine
    Posts
    Post Thanks / Like
    Thread Starter
    ADVERTISING BOX
    Thanks (and to Tampa8), I bought a box load of voltage converters from these sort of folks. OK, here comes the dumb question. I have a coax connector coming out of the wall, feeding from the Dish box several rooms away (just another issue of compatibility, I need an adapter to go from satellite coax to the UK standard coax, which I now have). None of these converters will take a coax input, they all want HDMI, component or one of the other video standard inputs. Is it possible to use an adapter to morph the coax to a useable input (I remember having a s-video to Scart adapter)? My Panasonic will take a wide range of inputs and can actually accept a NTSC signal through most of the 'video' inputs, just not through the antenna. Some of these converters are starting to get expensive and I can get a refurbished Visio 32" for just over $200 and save the headache. Maybe I just need to bite the bullet
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
