Results 1 to 4 of 4
09-19-2012 03:55 PM #1
H25-700 with Standard Non-HD Dish
I have an H25-700 receiver that I use at a different location on occasion. However, that location only has a standard dish (non-HD). Before I upgraded all the equipment everything worked fine. When I try to plug in the H25-700 HD receiver it does not work. Is there something I need to do differently to access my regular non-hd programming on this receiver using a standard dish or are the two not compatible?
Thanks!
09-19-2012 04:35 PM #2
The H25 will only work with a swm type lnb. That's the kind with only one output. A swm setup also needs a power inserter.
BTW, my name is Chip, Raoul5788 is just a screen name
09-19-2012 06:04 PM #3
a standard dish wont work.....
Directv Slimline SWM 5 LNB and DirectvWorld dish on the roof of the apartment building...Directv HR34 AKA Genie
All FTA stuff in storage right now
09-19-2012 06:48 PM #4Actually you could use an older Phase III dish and a swm lnb, but it's not the best arrangement. The Slimline dish and swm lnb is the way to go.
ADVERTISING BOX
Register To Reply
