Page 2 of 3 FirstFirst 123 LastLast
Results 7 to 12 of 18
Thread: Fortec 120cm fine adjustment on the cheap and easy
  1. #7
    Join Date
    Oct 5th, 2008
    Location
    West Coast Canada
    Posts
    137
    Post Thanks / Like
    Thread Starter
    I needed to be able to tighten the bolts without them having a load. For me, manhandling to tweak in micro adjustments and tightening the dish would always end in average results. With this, it doesn't bear any particular weight once the dish's elevation nuts are tightened (I made sure to use washers) so it should last as good as anything else in 8 months of rain per year. Looking at it now it couldn't have been easier and I am seeing signal levels that I've never had. I peaked the elevation with the turn buckle, then tightened the elevation bolts - the signal levels were unchanged. Once the nuts were tight, the adjuster doesn't have any real load on it but would be able to take a load if needed (wind?).
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
    Reigster at SatelliteGuys
  3. #8
    Join Date
    Sep 8th, 2003
    Posts
    413
    Post Thanks / Like
    Mad, it looks like the arm for your lnb is upside down. If it were flipped over then you could move the lnb back to the end of the arm and not have to use the block. I have a 90cm dish but the arm has that same bend as your dish and the directions showed it opposite as the way you have yours attached to the dish.
    Anyway, just a suggestion.
  4. #9
    Join Date
    Apr 7th, 2006
    Location
    up on the roof in SinCity
    Posts
    4,161
    Post Thanks / Like
    Quote Originally Posted by WTguy View Post
    tried that. thanks for the thought. even drilled holes to bring the support rods higher. shes parked at 125 and happy it does something.
    and i did not take the sledge hammer to it like i wanted too a few timeS. was told they sent me the wrong lnb holder twice none of the 3 worked right from the back hole(flipped). # 2 is on it.
    System
    C-band>13'BV/DH perf ,4-10'KTI 2 w/Ajak h-h,3-10'Wineguard 1 w/Ajak h-h , 7.5' KTI w/ Ajak h-h,7.5 Star Trak,8'Echostar, 7.5 Wineguard,
    Drake's 1824,1724,1624,GI-922,GI-920,Toshiba's 1520, 2220,GI 350,NextWave500,Prosat 390,Manhattan450
    KU>5)Fortec 36"90 cm, 6) STAB 100 & 120 Motors 1) Fortec 31"80 cm @97, 5 1meter Fortec's,2 90 cm WSI's,1)World dish,1) Wineguard 1 meter,1)1.2meter unstamped @125.
    Pansat's 2800,3500,9000HD,7>9200 S-2 HD,TC-1000,9500HDX
    Coolsat 8100,SV-8000 HD,Visionsat IV-200,Vantage HD1100S.Azbox Ultra & Premium Plus,. 7 OpenBox S9's
    HTPC=.Prof 7301,Hauppauge Colossus
    DIRECTV 3)HR20-100S's,HR23-700 For 3D,ChoiceX,NBA L Pass,Sports Pack,NHL CI
    the most important reading you might ever do.
    http://www.resurrectionism.com/drgenescott.html
  5. #10
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! SatelliteAV did! Help Support The Site And Get Rid of the Syndicated Ads, SatelliteAV did! If you enjoy the site consider supporting it, SatelliteAV did! Be COOL like SatelliteAV and Click a Star and become a Supporting Pub Member today!
    Join Date
    Sep 3rd, 2004
    Location
    Roseville, CA
    Posts
    6,085
    Post Thanks / Like
    Quote Originally Posted by madmadworld View Post
    The LNBF is not aimed into the correct area of the dish. The face of the LNBF shouls be aimed at the bottom third of the reflector. You are lucky if you are collecting half of the reflected signals.
  6. #11
    Join Date
    Oct 5th, 2008
    Location
    West Coast Canada
    Posts
    137
    Post Thanks / Like
    Thread Starter
    Fortec 120cm 1.2m dish assembly instructions
    Yes, good eye Brian - Mad's lnb support rods are Left / Right reversed and upsidedown. I've attached the assembly instructions for the fortec 1.2m dish.
    As Brian pointed out, the lnb is at the wrong spot for the focal point. If you have the lnb holder that came with the dish - it looks exactly like the one in the assembly instructions attached - it does work better than others I have tried on the dish.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Name:	fortec 120cm dish zoom1.jpg
ID:	81453   Click image for larger version.
Name:	fortec 120cm dish assembly1.jpg
  7. #12
    Join Date
    Apr 7th, 2006
    Location
    Posts
    4,161
    Post Thanks / Like
    thanks guys
    hoping you guys are right but may never touch that dish again unless become bored near death.
    still don't have that lnb holder. but did try all that were sent and moved that arm both ways for each.
    did not get any assembly instructions. would have helped at least would know Still have the wrong lnb holder. yet not sure it's a fortec no stamp on it all my others have one.
    kinda wrote it off as 1 bad saduon buy(unmarked Chinese junk) and everything else i got there was very good so...
    when ordered it was a white dish with the stamp well when opened it was that and things near never got better.
    will look around for That lnb holder. got other projects now. that sucker has been so frustrating my stomach churns now.
    my first big cband dish took less time out of the box.
    that said it gets all the pbs stuff really good for over a year now. yippee
    System
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
