Results 61 to 66 of 118
Thread: RTV 87W move?
10-03-2012 03:48 PM #61
83W RTV is doing ok as usual in Ohio. I've thought of raising my 8 foot dish up on another pole..In the summer I lose 58w to 72W & 137W on Cband...
KU seems to be ok between 72w and 125W....I may trim the one tree that is messing with 87W on CBand to see if RTV improves. I'm getting too old and lazy to climb like I used too.
Micro HD Receiver, 36" Primestar dish with SG2100 motor & GeoSat PPL Lnb scanning KU from 61W-125W, Fortec 8 Foot with Geosat CK1 Lnb, and HARL2424 Powertech acuator and Gbox scanning 61W-139W, Fixed 6 Ft Fortec dish for 43W-58W.
Vizio 47" HD/3D Tv with Roku XS and Gateway 3.6Ghz computer for streaming and HTPC. 91XG antenna for 35 plus OTA channels
My expensive hobbies have helped me keep my sanity and annoyed the neighbors
10-03-2012 03:48 PM # ADS
Register Today & This Ad Goes Away! Syndicated Advertisement- Join Date
- Always
- Location
- Advertising world
- Posts
- Many
10-03-2012 04:29 PM #62
Ku feed looks normal here. Which it should, as nothing has changed.
- TripN4MJC
RabbitEars.Info
Comments are my own and not that of my employer or anyone else.
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
10-03-2012 04:50 PM #63
I went outside and tweaked my lnb on Cband and RTV popped in a solid signal now on 87W. Bounces between 58-70..enough to keep it locked in no problem.
So RTV's signal and my huge tree weren't my issues after allShift+R improves the quality of this image. Shift+A improves the quality of all images on this page.
BlindMicro HD Receiver, 36" Primestar dish with SG2100 motor & GeoSat PPL Lnb scanning KU from 61W-125W, Fortec 8 Foot with Geosat CK1 Lnb, and HARL2424 Powertech acuator and Gbox scanning 61W-139W, Fixed 6 Ft Fortec dish for 43W-58W.
10-03-2012 05:08 PM #64AZBox Ultra HD + Pansat 3500SD + EMP Centauri 8x1 + 4x1 DiSEqC + 22KHz switchesAriza 80cm: G19 (97), AMC1 (103), Echo11 (110) / Fortec 80cm: G28 (89), G16 (99) / Fortec 80cm: Echo7 (119), AMC21 (125) / Ariza 80cm: Echo9 (121) / Star Choice 75e: Echo12 (61.5), AMC6 (72), AMC9 (83), SES2 (87), G25 (93) / SC 60e: HISPST (30) / SC 60e: G11 (91), G3C (95), SES1 (101) / SC 60e: (107.3), (111.1) SC subscription dish (+FTA)Avatar: 2008 setup 61.5, 72 or 74 (selectable), 79, 87
10-03-2012 06:42 PM #65
No change in the bitrate.... any chance it can be tweaked/raised a bit? Some shows on RTVE and PBJE are suffering.
The source material on shows like Skippy must be poor, as they show the effects more than some others.
Would like to see some of change of programming (more of a change than what just happened for the 4th quarter) Please try to add some series like Harbour Command, or Jungle Jim.
I don't want to sound all negative, I do enjoy what is there.Last edited by Larry1; 10-03-2012 at 06:57 PM. Reason: added negative comment
10-04-2012 09:27 AM #66I have not been able to scan in the feed on 87W on my Azbox Prem +, is there a cure for this? I should be able to get the signal, I am using a 10' mesh buttonhook BUD, and usually have no trouble getting a lock on DBV-S2. I have not tried the 137W feed yet.
ADVERTISING BOX
Thanks,Migold -
10' Mesh BUD Dual C-LBNF w/actuator driven by Drake ESR1624U (61W-139W) and 90 cm GeoSatPro w/ DG380 (61W-125W) both to Azbox Premium Plus HD, & 2.4 meter stationary (aimed to 99°W) with (1st) Dual C-LBNF to AZBOX Premium PLus HD & Pansat 9200HD and (2nd) offset C/Ku LNBF (for 105°W) to Motorola-922 4DTV [Subscribed]. Viewing on Sony KDL-46XBR9, Sony KDL-32EX500, and other sets throughout the house. PLUS OTA VHF Hi-Band Yagi+Amp; HDTV Antenna w/Internal Booster from 'antennashopusa' on ebay; & 16 Bay AntennaCraft Super G-1483 (Gray-Hoverman) modified +Amp.
Register To Reply
