Results 1 to 6 of 18
10-08-2012 09:35 PM #1
Can't get RTP with microhd (but do with another receiver)
My parents are renovating their new house, and I thought this would be the best time to also upgrade all of their old A/V equipment. After some research I decided to buy the microhd receiver to replace my dads old Coolsat 5000, which would give him the ability to record his shows without the VCR.
We pointed it to 97W with our motorless 1m dish and get about 72-74% signal. The receiver seems to work fine, bringing in over 300 channels, except it doesn't get the only channel my dad watches, RTP.
The same dish, with the same cable, and same settings on the Coolsat works flawlessly. RTP comes up no problem with at least 72% signal. When I scan the TP 12060H 22000 with the microhd however, I get 3 channels that are actually from 12053H 22000. I wont get any channels that are on the list for 12060H despite having 73% signal most of the time. Increasing the frequency will give me no results until 12074H which will then be the 12083H channels. A detailed and normal blind scan get me a bunch of channels, but still no RTP. When I manually look for the PID -> VPID 2001, APID 3001, I get no results.
I've done a factory reset, upgraded to the latest firmware, and did a factory reset after that but I get exactly the same results every time.
Am I doing something wrong, missing a setting, or do I just have a buggy receiver?
Warning: This is an Old Thread
This discussion is older than 90 days. information contained in it may no longer be current
10-08-2012 09:35 PM # ADS
Register Today & This Ad Goes Away! Syndicated Advertisement- Join Date
- Always
- Location
- Advertising world
- Posts
- Many
10-08-2012 10:04 PM #2
RPTi scans in with no issues. Probably the LNBF LO frequency has drifted. If 12053 channels scan when preprogrammed TP 12060 is searched, the LO frequency is likely no longer at the correct frequency.
Delete all channels and transponders then perform a blind scan of G19. You will notice the the frequencies that scan will not match the published frequencies. Sounds like it is time to replace the LNBF.
Satellite AV, LLC (Gold Sponsor)
Equipment Development / Distribution / Repair / Call Center
888-483-4673 - http://www.satelliteav.com
eBay Special Deals
Attention Installers: Want more work? Join the Largest Satellite Technician Referral Website - www.FTAinstall.com
10-08-2012 10:48 PM #3
SatelliteGuys Freshman
- Join Date
- Oct 8th, 2012
- Location
- Canada
- Posts
- 7
- Post Thanks / Like
- Thread Starter
I tried scanning at a friends house who also uses a Coolsat for RTP, but with a dual LNB on his dish and I got the same results.
If my LNB is off, how does the Coolsat find the channel, but not the microhd? Shouldn't a blind scan be able to pick it up even if it was off?
If I were to buy a new LNBF, anything I should be looking for in particular to get this channel?
Thanks for the reply
10-08-2012 11:34 PM #4
Delete all channels and transponders then Blind Scan again. The channel scans in as RTPi America. There are 16 TV channels on this transponder:
RTPi America
Emmanuel TV
PNG
Asre Emarooz TV
3ABN Proclaim TV
Melli TV
ORTM
Al Hyat TV
LoveWorld TV
Gem TV
Tele Anacaona
Appandana
E2 Channel
CTN-Christian Television Network
TV Verdade
GCN
Are you receiving any of these channels?
If the same scan result on another LNBF and dish, then it is not likely a LNBF issue.
Blind Scan will find a transponder even if LO has drifted, but the transponder frequency will not be correctly logged.. Often a receiver will tune a channel that has been previously scanned, but will not log a channel during a TP scan of the LO frequency is too far off.Satellite AV, LLC (Gold Sponsor)
eBay Special Deals
10-09-2012 07:17 AM #5
- Join Date
- Oct 8th, 2012
- Location
- Canada
- Posts
- 7
- Thread Starter
I'm not 100% sure since I don't have the receiver with me, but I'm pretty sure the channels in that area went like this:
ORTB -12053
Press TV -12053
Eburu -12083
Samanyolu -12083
Emmanuel TV does look familiar though, so I will have to double check.
I won't be able to check until the weekend, but if he are any more suggestions, I'll make sure to put it on my list
10-09-2012 11:38 AM #6working fine here in Minneapolis on my Micro
ADVERTISING BOX
Directv Slimline SWM 5 LNB and DirectvWorld dish on the roof of the apartment building...Directv HR34 AKA Genie
All FTA stuff in storage right now
Register To Reply
