Quantcast
771a error on one receiver
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Welcome HOME to SatelliteGuys! We are America's Most Popular Satellite Forum!
Page 1 of 3 123 LastLast
Results 1 to 6 of 14
  1. #1
    Join Date
    Jul 31st, 2006
    Posts
    94
    Post Thanks / Like
    I have 2 dvrs and one hr24 hd receiver. I've never use the he receiver until today when I connected a tv. The 2 dvrs are ok but the standard hd receiver gets a 771a error. Ive checked all the wiring and all was ok. One thing.. When I first turned it o with the tv, it showed a picture from CNN but was frozen and then had a 771a error. I called directv and they are coming out Thursday. I'm hoping I may be able to resolve before then.
    Any help appreciated.... Thanks....
    Sent from my iPad using Tapatalk HD
  2. #2
    Join Date
    Jul 31st, 2006
    Posts
    94
    Post Thanks / Like
    Thread Starter
    Just looked at directv app for iPad. Received with 771a error was showing red. Now it is green and I can press the turn off button and it does turn off the receiver. When I run the network test under menu, I get a 51-938 no swm detected.. I can also press list and see all the recorded shows from my other dvrs although they will not play..... Any ideas?
  3. #3
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! raoul5788 did! Help Support The Site And Get Rid of the Syndicated Ads, raoul5788 did! If you enjoy the site consider supporting it, raoul5788 did! Be COOL like raoul5788 and Click a Star and become a Supporting Pub Member today!
    Join Date
    Dec 28th, 2004
    Location
    Cheshire CT
    Posts
    12,495
    Post Thanks / Like
    Have you checked the RG6 cables and connectors?
    BTW, my name is Chip, Raoul5788 is just a screen name
  4. #4
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! BobStokesbary did! Help Support The Site And Get Rid of the Syndicated Ads, BobStokesbary did! If you enjoy the site consider supporting it, BobStokesbary did! Be COOL like BobStokesbary and Click a Star and become a Supporting Pub Member today!
    Join Date
    Jul 9th, 2009
    Location
    Southern California
    Posts
    412
    Post Thanks / Like
    I know you said you checked all the wiring, but 771A error basically says that your receiver cannot connect to a SWM signal and the typical reason is that a coax cable is loose. It can also mean a bad connection. You need to remove all the connections and make sure that the wiring is OK. Then put them back together and make sure they are snug. There is a slim possibility that one of the ports on your splitter is not capped. Any unused port needs a 70 ohm terminator (it sort of looks like a chrome tire valve stem cover with a bump on it). Make sure there are no open connections. If all that is good, it looks like you will have to wait until Thursday for the tech.
  5. #5
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! Jimbo did! Help Support The Site And Get Rid of the Syndicated Ads, Jimbo did! If you enjoy the site consider supporting it, Jimbo did! Be COOL like Jimbo and Click a Star and become a Supporting Pub Member today!
    Join Date
    Jul 14th, 2005
    Location
    NW Ohio - Buckeye Country
    Posts
    42,605
    Post Thanks / Like
    Quote Originally Posted by BobStokesbary View Post
    I would start checking the cables with the recvr that is getting the error, follow it back to the SWM splitter and remove and change compression fittings on that cable. (provided that it's not happening on all your connected recvrs)
    As for terming the left over connections on the splitter, don't think it's necessary, many of mine are left open and all work fine. My connections are inside behind the TV, not outside, if his is outside then yes I would cap them.
    2 HR24-500's, 2 HR24-100's, SL3 Dish, SWM Dish, AM21, 60" Pioneer Elite, 2 - 42" Pioneer Elite's, Seagate 1.5 TB EHD
  6. #6
    Join Date
    Jul 31st, 2006
    Posts
    94
    Post Thanks / Like
    Thread Starter
    ADVERTISING BOX
    I checked all connections. I assume since I was able to press list and see the recordings on the other DVrs in the house that wiring is ok. All unused connectors are capped and all wiring is on my garage then going to the rooms. What's next? Or wait for service ? Thanks...
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
