Quantcast
Newsfeeds on the 1.2m. Not what they used to be.
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Welcome HOME to SatelliteGuys! We are America's Most Popular Satellite Forum!
Page 1 of 4 123 ... LastLast
Results 1 to 6 of 20
  1. #1
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! Panavision did! Help Support The Site And Get Rid of the Syndicated Ads, Panavision did! If you enjoy the site consider supporting it, Panavision did! Be COOL like Panavision and Click a Star and become a Supporting Pub Member today!
    Join Date
    Jan 23rd, 2007
    Location
    St. Louis Park, Minnesota
    Posts
    232
    Post Thanks / Like
    I've been having trouble keeping a consistent lock on DVB-S2 8PSK 5/6 Ku on my 1.2m Andrew. My quality hovers right around 70% on my Micro and this is just enough to keep the audio going, but the video breaks up every few seconds. This never seemed to be a problem with DVB-S MPEG-2 in the past. Is S2/8PSK/MPEG4 really that much harder to pull in? I thought a good 1.2m would be sufficient. Have others been let down by how their systems deal with this higher-order modulation?
    Warning: This is an Old Thread
    This discussion is older than 90 days. information contained in it may no longer be current
    GEOSATpro MicroHD, DSR-200c, Quali-tv QS1080IR, 2-Andrew 1.2m dishes, 2-Channel Master feedhorns, Andrew Orthomode Transducer, 2-Norsat 4206A Ku LNBs, Invacom QDF-031 LNB (spare), Fortec Star 1.2m dish aimed at 103w, GEOSATpro SL1 PLL LNBF, Ariza 90cm dish aimed at 85w, Invacom SNH-031 LNBF, SG2100 Motor
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
  3. #2
    Join Date
    Mar 15th, 2005
    Location
    Michigan
    Posts
    2,018
    Post Thanks / Like
    It's the 5/6 fec that's probably affecting you most. You MUST completely re-tweak your dish, and lnb to make sure you are getting every single bit of quality you can get. This might mean eliminating couplers and switches, or changing them out for ones with less loss, or even better quality cable. Even 1 db of signal is 26%, and could be the difference between getting it or not. You need to try for 74-75% if at all possible. My DiSEQc switch is rated for only 1.5db loss, and MOST of them are rated at 3db loss! 3db is 1/2 your signal.
  4. #3
    Join Date
    Jan 23rd, 2007
    Location
    Posts
    232
    Post Thanks / Like
    Thread Starter
    Yeah, it really is those darn 5/6 feeds because 3/4 are fine at 70%. I experimented by removing the switches and didn't see any change. I'm running only 50 ft. of RG11 to my motor. I wonder if it has anything to do with my Channel Master feed horn. I got a 10% boost in quality on G16 by moving the feed horn closer to the dish by about 3/4 inch. I'm in MN, am I on the fringe of many footprints?
  5. #4
    Join Date
    Mar 15th, 2005
    Location
    Michigan
    Posts
    2,018
    Post Thanks / Like
    I don't know, I have no need to check sat footprints out as far as Minnesota. Use this site to figure it out:
    http://satbeams.com/
    Get rid of this ad below, as well as the link redirect by becoming a Supporting Pub Member
    Also use Lyngsat to check the "EIRP" power level for your location. The higher the number, the easier to receive that transponder. You have to check each individual satellite you actually want to receive for this.
    By the way, I think a good 3 ghz swept quad-shield RG-6 cable is actually better then some RG-11 cable. I've exclusively used quad shield RG-6 for over 10 years, and it works well for me. I use Thomas & Betts connectors, and never use just plain crimped connectors.
  6. #5
    Join Date
    Sep 6th, 2012
    Location
    Beaumont,Texas
    Posts
    77
    Post Thanks / Like
    Get Rid of this Ad! Register Today!
    Well I am locked in with my 1.2 meter dish and I am getting 70-78 quality on all sats from 72 to 125 with some up to 83-85 quality on my micro hd. I have to say I pull in tons of news feeds, more at certain times of the day. Heck my entire channel list right now in just a month of scanning is over 1400 and if you take away the 200 channels from G 25 and the other 50 or so from all the other sats then I have scanned in around 1150 or so feeds so far in just a month, well its been a month since I deleted my channel list. So I would say there is still tons of new feeds, in fact I can honestly say usually during the day up until around 7 or so in the evening it is nothing to scan in 5-10 new feeds every time I scan G 17 at 91* or the 99* bird. some such as the SES2 at 87* or the amc 9 at 83* dont have many news feeds, but sats 89,91,and 99 have tons of news on them so I would try to align your dish a little better.
  7. #6
    Join Date
    Jan 23rd, 2007
    Location
    Posts
    232
    Post Thanks / Like
    Thread Starter
    ADVERTISING BOX
    Yep, sounds like an alignment is in order!
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
