Quantcast
this motor is driving me nuts!
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Page 1 of 4 123 ... LastLast
Results 1 to 6 of 23
  1. #1
    Join Date
    Sep 6th, 2012
    Location
    Beaumont,Texas
    Posts
    77
    Post Thanks / Like
    I know I have asked alot of questions but I am having this issue!
    Today I come home and moved the dish over to 91, well I thought 91*. I scanned and noticed I was getting CCTV and was like what the?
    Somehow my motor moved like 3.5 degrees! I dont know how! weirdest thing I have ever seen with this motor! My dish didnt move!
    I have tightened my motor slack adjustments and cant tighten them any more! I have tightened down the motor clamp to the mount, the dish bracket to the motor,ect.
    I still notice when I swing out to 125 and go back it throws my sats off a few degrees every time! I am just about to breaking point!
    If I cant get it going I am just gonna buy a new motor! Does it look like I am missing something here? I tightened the slack all the way, the motor clamp and dish bracket to motor are all really tight! I dont know what is going on! It didnt start doing this until a week or so ago!
    Warning: This is an Old Thread
    This discussion is older than 90 days. information contained in it may no longer be current
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
  3. #2
    Join Date
    Dec 26th, 2006
    Location
    Oneonta,AL
    Posts
    8,171
    Post Thanks / Like
    Have you tried another receiver already, with this motor? Sorry if you have been asked already, I've slept since then lol. Also, how's the motor-to pole brackets looking? Didn't bend, did they?
    Icon 550, Vantage 1100HD (thanks Stogie) on .90M primestar DG380 motor.10'Sami+GI650 for c-band.
    CS5000 now on 1m primestar-polar mount backup system.
    Avatar: Bengal tiger. Think you have a real kitty?
  4. #3
    Join Date
    Mar 15th, 2005
    Location
    Michigan
    Posts
    2,009
    Post Thanks / Like
    Are you SURE your dish isn't moving from side to side? The reason I say so, is because that one carriage bolt that bolts through the dish mount and through the bent pipe coming off of the motor usually is smaller than it should be. So, the dish can flop over a bit, and that could easily be enough to explain 3~ degrees. To fix it, you remove the screw, drill the hole out a little larger, and use a larger bolt that fits TIGHT and allows no slack.
  5. #4
    Join Date
    Sep 6th, 2012
    Location
    Beaumont,Texas
    Posts
    77
    Post Thanks / Like
    Thread Starter
    the pole is fine and the motor to dish bracket are very tight, I dont think too tight on the motor to dish bracket would cause it to not move all the way.
    What it is doing now is when i move to say 72 to 95 it is doing fine and back to 72, but when i go say from 72 to 113 it doesnt go all the way to 113, it might stop .4 degrees or so short of the sat. I went back and fine tuned all the sats and tried it out and that is what it is doing, it isnt passing the sats, it is stopping just a hair before it gets to them. their is no to little wind outside.
    now when i go out to 125 and then swing back to 91 it stops a half degree or more before it gets to 91, then i have to fine tune all my sats again!
    if it is a slack problem wouldnt i have problems going from 72 to 99 and back and forth in and between? the slack adjustment is very tight, I tightened them up enough to where the dish wouldnt even move then loosened them until the dish can move and thats where it is now, it is moving slower than before. I dont see how loosening them more would make the dish drive farther.
  6. #5
    Join Date
    Sep 3rd, 2004
    Location
    Roseville, CA
    Posts
    5,686
    Post Thanks / Like
    Get Rid of this Ad! Register Today!
    Using USALS or DiSEqC 1.2?
    Satellite AV, LLC (Gold Sponsor)
    Equipment Development / Distribution / Repair / Call Center
    888-483-4673 - http://www.satelliteav.com
    eBay Special Deals
    Attention Installers: Want more work? Join the Largest Satellite Technician Referral Website - www.FTAinstall.com
  7. #6
    Join Date
    Nov 9th, 2009
    Location
    canada
    Posts
    787
    Post Thanks / Like
    ADVERTISING BOX
    sounds like the motor has moved on the pole, doesnt matter how tight you do up those bolts, a very heavy wind can cause the motor to rotate on the pole
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
