Welcome HOME to SatelliteGuys! We are America's Most Popular Satellite Forum!
Results 1 to 4 of 4
Thread: Sadun Motor DD-280 does not move
  1. #1
    Join Date
    Sep 7th, 2003
    Location
    Canton, Ohio
    Posts
    443
    Post Thanks / Like
    I had my receiver (Openbox s9) on 72w with a good signal but found I could move the motor no further west with the receiver..Checking outside, I found I cound maually move it all the way east, but it's just frozen in that spot..Clicking noise on both east and west buttons, though the lights still work..Ive tried everything I could think of..One question though..what exactly is "shift 0" on the Openbox remote?..
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
    Reigster at SatelliteGuys
  3. #2
    Join Date
    Dec 26th, 2006
    Location
    Oneonta,AL
    Posts
    8,795
    Post Thanks / Like
    That's a good question! I see it in the manual for the DG380 too but I never have figured out a way to do it. Luckily there are other methods for resetting the motor, like holding down both buttons at the same time for 5 seconds after disconnecting the coax from receiver.
    X2 Premium HD, 1m primestar DG380 motor.10'Sami+GI650 for c-band.
    Backup ku system currently being updated.
    Avatar: Bengal, big yawn.
  4. #3
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! Jim S. did! Help Support The Site And Get Rid of the Syndicated Ads, Jim S. did! If you enjoy the site consider supporting it, Jim S. did! Be COOL like Jim S. and Click a Star and become a Supporting Pub Member today!
    Join Date
    Jan 2nd, 2006
    Location
    upper Northumberland County, PA
    Posts
    4,029
    Post Thanks / Like
    When my DG-280 decided to go one direction only, no amount of resetting it helped. (And I never did figure out how to translate that mumbo-jumbo in the manual into something I could do on my Openbox, either!) Digging through the archives here revealed that it was most likely a stuck relay. So I opened it up, figuring that it'd be a no-brainer to unstick. Nope! They used those little micro-relays that you can't pull the cover off of. (Gee, if you're gonna go that small, why not use an optocoupler and eliminate a mechanical failure point? Surely someone makes an optocoupler that can handle that much current these days.) I tried to look up the part number of the relay online, and nobody seemed to carry them anymore. Rather than try to find a substitute, I looked around and found that, at the time, Sadoun was selling replacement boards for the DG-280 on ebay for about half the price of a new motor. So I bought one of them, and then when I went to replace it, I was further annoyed to find that somewhere between when my motor was made and when my replacement board was made, some genius had turned around the cable that connects the main board to the board that's connected to the actual motor, so that the plug-end was now the hardwired-end and vice-versa! So I ended up doing a whole lot more soldering than I intended (it should've been none at all). But at least my motor worked again. Hopefully it works longer than the ~18 months it worked on the first board!
    Dish 1000.4 Eastern Arc dish, Hopper With Sling, Onkyo 606 receiver, Samsung 46" LCD
    GeoSatPro 90cm dish, Sadoun PowerTech DG-280 motor, DMS Avenger PLL321S-2 LNBF, Amiko Alien 2 receiver
  5. #4
    Join Date
    Dec 16th, 2009
    Location
    Grapevine, Arkansas
    Posts
    48
    Post Thanks / Like
    I have a similar problem with my DG-270 motor and it will move manually to the West, but will go back to the East all the way. I get good signals on my receiver, but can't get any channels due to this problem. I will try disconnecting the cable from the motor and pressing the buttons for 5 seconds to see if that helps.
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
