Quantcast
Doing HD upgrade with no contract question
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Welcome HOME to SatelliteGuys! We are America's Most Popular Satellite Forum!
Page 2 of 2 FirstFirst 12
Results 7 to 11 of 11
  1. #7
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! TheKrell did! Help Support The Site And Get Rid of the Syndicated Ads, TheKrell did! If you enjoy the site consider supporting it, TheKrell did! Be COOL like TheKrell and Click a Star and become a Supporting Pub Member today!
    Join Date
    Jan 4th, 2007
    Location
    Fairfax, VA
    Posts
    7,093
    Post Thanks / Like
    Quote Originally Posted by bobvick View Post
    I have a couple of DPP LNB's that go on a 500. What do I need for the DPP LNB's and a legacy for 129, will a DP-21 work or do I need a DP-34?
    There are no DPP LNBs since such a thing would make no sense. If you actually have a DPP twin, then (like all twins) that has a built-in switch and it would be good to upgrade your friend to it. One DP dual on the dish for 129 cabled into the DPP twin, and then one cable each to his 322 and the 211.
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
  3. #8
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! boba did! Help Support The Site And Get Rid of the Syndicated Ads, boba did! If you enjoy the site consider supporting it, boba did! Be COOL like boba and Click a Star and become a Supporting Pub Member today!
    Join Date
    Dec 12th, 2003
    Location
    Dorchester, TX.
    Posts
    8,292
    Post Thanks / Like
    It all depends on existing electronics, what Krell says a DPP Twin on a dish 500 and a DP single or dual on a second dish is preferred way to add Hd for 2 receivers.
  4. #9
    Join Date
    Sep 29th, 2005
    Location
    Greentown, Pennsylvania, United States
    Posts
    7,172
    Post Thanks / Like
    I am not sure of the LNB's I have a couple of DPP LNB's that go on a 500. What do I need for the DPP LNB's and a legacy for 129, will a DP-21 work or do I need a DP-34?
    If you have DP or DPP on the D500, a legacy lnb for 129 will not work.
  5. #10
    Join Date
    Nov 21st, 2009
    Location
    Wild West
    Posts
    186
    Post Thanks / Like
    Ok, lets clear the air here. There are DPP LNB's. The Dish Pro Plus Twin (which is probably what your friend is using if he already has a 322 hooked up.) There is also Dish Pro Plus 1000.2/1000.4 - Eastern or Western Arc.
    If you're friend has a DPP Twin pointed at 110/119 a wing dish could be put up pointing at 129. You would want to use a DP Single LNB for the wing dish. The DPP Twin has an 'LNB In' connection on it, so you can switch in an additional satellite.
    You can also switch the dish 500 with a new dish 1000.2 and matching LNB.
    Either way, no external switching is needed. If, for whatever reason, you need to do an external switch, the DPP33 would be recommended as you would only need to run 1 cable to the 322. Whereas with the DP34 sw you would need to run 2 cables to the 322.
    Also, if you're using a DPP Twin and decide to use an external switch, either of the ones mentioned above (DPP33 and DP34) will not work correctly with the DPP Twin. You would want to swap the DPP Twin with 2 DP singles.
    Hope this helps.
  6. #11
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! bobvick did! Help Support The Site And Get Rid of the Syndicated Ads, bobvick did! If you enjoy the site consider supporting it, bobvick did! Be COOL like bobvick and Click a Star and become a Supporting Pub Member today!
    Join Date
    Jul 20th, 2006
    Location
    NW Alabama
    Posts
    1,290
    Post Thanks / Like
    Thread Starter
    ADVERTISING BOX
    I appreciate all of the help. If I had the time, I think that I have the parts to do it. Unfortuniately, I would have to probably run cable in some pretty tight places to get everything where it needs to be, and there is the matter of finding the time to do it. I have adivsed him that it would be simpler to just have Dish Network to do it. Again, I apprecaite the help.
    DIRECTV AU9-SL3 dish, SWiM 16, HR34-700, HR24-100 w/ ext 1TB HDD, HR24-200, HR24-500, HR24-100 w/ ext 2TB HDD, nomad, AM21 OTA tuner (2), DECA Networked
    SAMI 7.5' C-Band dish, Chaparral Dual-C feed, Norsat 8115 15 deg C-Band LNB's
    Manhattan RS-1933, Pansat 9500HDX, GBox V-7000 positioner
    Channel Master UHF/VHF antenna, Channel Master roter, 60' tower antenna
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
