Quantcast
30w
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Page 1 of 8 123 ... LastLast
Results 1 to 6 of 46
Thread: 30w
  1. #1
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! danristheman did! Help Support The Site And Get Rid of the Syndicated Ads, danristheman did! If you enjoy the site consider supporting it, danristheman did! Be COOL like danristheman and Click a Star and become a Supporting Pub Member today!
    Join Date
    Jan 25th, 2011
    Location
    Angola Indiana
    Posts
    450
    Post Thanks / Like
    30w
    just got 30w tonight will post pics tommarow got 30% quality with my slimline dish with dishnetwork super dish lnb.
    Dan Rose
    Warning: This is an Old Thread
    This discussion is older than 90 days. information contained in it may no longer be current
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
  3. #2
    Join Date
    Jan 25th, 2011
    Location
    Angola Indiana
    Posts
    450
    Post Thanks / Like
    Thread Starter
    here are some pics of my mortar tube i call it that I use for my satellite dish holder.Click image for larger version.
ID:	82080Click image for larger version.
ID:	82081Click image for larger version.
ID:	82082Click image for larger version.
ID:	82083Click image for larger version.
ID:	82084Click image for larger version.
ID:	82085Click image for larger version.
  4. #3
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! phlatwound did! Help Support The Site And Get Rid of the Syndicated Ads, phlatwound did! If you enjoy the site consider supporting it, phlatwound did! Be COOL like phlatwound and Click a Star and become a Supporting Pub Member today!
    Join Date
    Dec 25th, 2007
    Location
    Hillbillistan (SW MO, USA-37N 93W)
    Posts
    2,700
    Post Thanks / Like
    Good job on getting 30W, that one can be a challenge.
    I'm guessing that LNBF is looking for a "round" (offset oval) dish, so it probably isn't being illuminated by all of your Slimline.
    That is probably the same situation I had on one of my 30W experiments, a LNBF that was not being fully illuminated by a Slimline (elliptical) dish.
    Don't know if it would help you any, or if you want to mess with it, but you might try setting your LNBF to zero degrees skew, and skewing your whole dish instead. Here is a thread with some pics of how I did it, might give you some ideas.
    http://www.satelliteguys.us/threads/...e-fixed-on-30W
    C-Band: 12' Unimesh/AJAK 180/GeoSat C2***10' "Perfect 10" mesh/GeoSat C2*** 8.5' Birdview solid/BV H-H/GeoSat C2*** 7.5' Unimesh/CalAmp voltage-controlled LNBF***...C-Band LOS from 58W-139W
    Ku-Band: 3ABN .9m/SL1PLL LNBF/SG2100***Fortec .9m/TrackerII LNBF/STAB HH90***7.25' Birdview "Spoon"/TrackerII/70:1 BV H-H***Prodelin 1.8m/GeoSat Bullet/AJAK 180 H-H***Paraclipse Hydro 1.5m Prime Focus/Linear Actuator/C120 LNBF...Ku-Band LOS from 30W-129W
    Receivers: Toshiba TRX-1820 Analog-->AZBox Elite/Openbox S9 HDx2***GeosatPro microHD
    OTA Digital: CM 4228/CM 7777 Preamp/Apex DT-250 for OTA Locals, Toshiba 46" Regza & Toshiba 19" LCDs
    In Progress: (2) Birdview 8.5' (1 solid & 1 perf) w/Birdview H-H mounts, "Drake" 10' solid alum....*BVOC Asst. Cook & Bottlewasher*
  5. #4
    Join Date
    Jan 25th, 2011
    Location
    Angola Indiana
    Posts
    450
    Post Thanks / Like
    Thread Starter
    I had to use what I had to work with. i'll check that out the post you made about you getting 30w.
    dan rose
  6. #5
    Join Date
    Sep 22nd, 2005
    Location
    L.A., Calif.
    Posts
    10,613
    Post Thanks / Like
    elliptical this 'n that
    Get Rid of this Ad! Register Today!
    Elliptical dishes always come with a skewable mount.
    Elliptical dishes should always be skewed.
    An elliptical feedhorn will illuminate the entire dish surface.
    An elliptical dish with matching feedhorn will have the beamwidth of a round dish of the same width.
    Signal level may be a bit lower, but adjacent bird interference will be reduced, raising sig Quality.
    A round feed gets signal from entire dish width, but nothing beyond top & bottom dish edges.
    This raises the noise level, lowering performance (which may be fine on strong signals).
    Regardless of all the above, feedhorn efficiency plays a role.
    example of good: Primestar 84e
    example of poor: SuperDish 121
    Medeocre band stacked FSS LNBs can be much improved with a better feedhorn.
    eg: discussion by Pendragon
    http://www.satelliteguys.us/threads/...ht=Bandstacked
    See this thread by Tech#344, also recommendation for better lot numbers of LNBs
    http://www.satelliteguys.us/threads/...highlight=Dp34
    There are other good "how I made my own Feedhorns" stories on the forum.
    Do we need an elliptical dish FAQ?
    Secondary LNBFs mounted off to the side of the central LNBF play by different rules, which distract from the simplicity of this discussion.
    laboriously typed on my iPhone 4.
    Straight Talk on AT&T iPhone 4, iOS 5.0.1, BB 3.10.01.
    Retired Apple iPhone 3GS, iOS 5.0.1, BB 6.15.00.
    I repaired smashed screen & more on both.
    : BirdView 8½' solid & GBox V3000.
    AMCI 8' perf (maybe a DH?) & AJAK-180.
  7. #6
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! Bongu did! Help Support The Site And Get Rid of the Syndicated Ads, Bongu did! If you enjoy the site consider supporting it, Bongu did! Be COOL like Bongu and Click a Star and become a Supporting Pub Member today!
    Join Date
    Oct 19th, 2010
    Location
    Chicago Burbs
    Posts
    442
    Post Thanks / Like
    ADVERTISING BOX
    I agree with skewing the dish. I dont see any skew on the feed that you have installed on it from the pictures. for me, 30W is a pretty radical skew:
    Your Location Satellite Data Dish Setup Data
    Latitude: 42.1656°
    Longitude: -88.2942°
    Name: 30W HISPASAT 1C | HISPASAT 1D | HISPASAT 1E | SPAINSAT
    Distance: 40112km
    Elevation: 14.5°
    Azimuth (true): 112.5°
    Azimuth (magn.): 115.8°
    LNB Skew [?]: -43.2°
    Sat locations I can use, Sat names mean nothing to me!
    Ku setup: Winegard 3100, Invacom QPH-031, DG-380 (jury is still out on this setup - tighter beam patterns giving me alignment fits)
    C-Band setup: No dish up currently, Chapparal ortho w/ 8115's, Vbox-X
    Receivers: Sonicview 8000HD, Viewsat 2000 Ultra, Prof 7301, Digitrans DVB/DCII DTE-7150, DSR-922, Skybox F3, Geosat Pro MicroHD
    Hardware in storage: Winegard 2076, SG-2100, SL2 bullet LNBF, 10' KTI buttonhook, Prodelin 1.8m Ku fixed, numerous DirecTV and Dish reflectors
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
