Quantcast
no power from receiver to lnb
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Welcome HOME to SatelliteGuys! We are America's Most Popular Satellite Forum!
Page 1 of 3 123 LastLast
Results 1 to 6 of 14
  1. #1
    Join Date
    Oct 31st, 2012
    Location
    california
    Posts
    9
    Post Thanks / Like
    Hi all. Wondering if.someone can help me out. My.sonicview 360e all the.Sudden stopped getting signal and quality. Tried all kinds of.settings even hooked up a diferent receiver and it.did.get signal. So, it.appears that the part that sends power to lnb is not working. My question is what options might I have being that, I have.other receivers, pansat and viewsat , to make my sonicview work. Also, can the part that is bad be replaced? Where can I order part and how.do.I replace?. Thanks so much.
    Warning: This is an Old Thread
    This discussion is older than 90 days. information contained in it may no longer be current
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
  3. #2
    ke4est's Avatar
    ke4est is online now Michael -- Long Live FTA
    Proud SatelliteGuys Staff Member
    Proud Staff Member
    Join Date
    Aug 9th, 2004
    Location
    Far West -- Western North Carolina
    Posts
    12,177
    Post Thanks / Like
    Welcome to Satelliteguys!!!
    ke4est @ SatelliteGuys.US If You Want To Stay Ahead Of The Rest, Please Click Here----Always Here To Help!!
    Do you enjoy a good brew, then come join us at brewcrew.net.
  4. #3
    ke4est's Avatar
    Proud Staff Member
    Join Date
    Aug 9th, 2004
    Location
    Posts
    12,177
    Post Thanks / Like
    You can try looping through, but would get aggravating as you would only get H or V depending how the other rx is set. Pop the top and see if ant caps in PS look poped or swollen.
  5. #4
    Join Date
    Sep 22nd, 2005
    Location
    L.A., Calif.
    Posts
    10,623
    Post Thanks / Like
    There IS an option to turn on/off LNB power, but I willl assume you have that set correctly in the receiver configuration.
    IT does pay to double check.
    If the receiver has actually failed, then components surrounding the LNB power regulator *may* be at fault.
    There should be a 3-terminal regulator on the receiver board
    Usually, it's black, epoxy,and has a metal tab bolted to a heatsink, or the chassis.
    If you post some (good) pictures and we can locate the part, we might come up with some ideas to test it.
    Alternately, as ke4est mentioned above, the problem is just as likely to be on separate power supply board.
    One tell-tale sign is leaking or bulging-top capacitors.
    These are little vertical cylinders, with two leads at the bottom, going into the board.
    They're normally crimped shut and flat on the top.
    If bulging, or leaking from the bottom, that's a clue.
    (not to be confused by sloppily-applied glue to hold them in place!) .
    Straight Talk on AT&T iPhone 4, iOS 5.0.1, BB 3.10.01.
    Retired Apple iPhone 3GS, iOS 5.0.1, BB 6.15.00.
    I repaired smashed screen & more on both.
    : BirdView 8½' solid & GBox V3000.
    AMCI 8' perf (maybe a DH?) & AJAK-180.
  6. #5
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! danristheman did! Help Support The Site And Get Rid of the Syndicated Ads, danristheman did! If you enjoy the site consider supporting it, danristheman did! Be COOL like danristheman and Click a Star and become a Supporting Pub Member today!
    Join Date
    Jan 25th, 2011
    Location
    Angola Indiana
    Posts
    450
    Post Thanks / Like
    Get Rid of this Ad! Register Today!
    I have a sonicview 360 premier had the same problems what I did was just reset the box turn it off then turn it back on. It works I was on galaxy 19 and KTV 1,2,3 wouldn't come in check my 1000 in the living room it was picking up just fine. I also lost other channels like Russia today so just turn it off and on.
    Dan Rose
  7. #6
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! Kraven did! Help Support The Site And Get Rid of the Syndicated Ads, Kraven did! If you enjoy the site consider supporting it, Kraven did! Be COOL like Kraven and Click a Star and become a Supporting Pub Member today!
    Join Date
    Jun 2nd, 2012
    Location
    Northern, VT
    Posts
    2,045
    Post Thanks / Like
    ADVERTISING BOX
    [QUOTE=Anole;3010775]There IS an option to turn on/off LNB power, but I willl assume you have that set correctly in the receiver configuration.
    IT does pay to double check. [QUOTE]
    Was going to suggest the same thing.
    Cheers, K
    39" Ku, 6ft BUD, VS Ultra, Micro HD, Openbox s10 (cannon fodder), channel master 4228HD, CM7777 Preamp, Homemade Yagi, PS3, XBOX 360, Wii, Original Roku
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
