Quantcast
Dish aiming problem
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Welcome HOME to SatelliteGuys! We are America's Most Popular Satellite Forum!
Page 3 of 3 FirstFirst 123
Results 13 to 16 of 16
  1. #13
    Join Date
    Apr 12th, 2006
    Posts
    1,438
    Post Thanks / Like
    See my post. 99% of the time a problem with the even transponders on 103 is caused by a faulty cable/connectors from the dish to the 103/110/119 18v connector on the SWM8. That cable carries the 103 evens. Since the OP does not have a Slimline 5 you can't see the 110/119 satellites - if he did have a Slimline 5 you would see the even transponders were missing on those also.
    Although a faulty SWM8 could possibly cause this, it's very unlikely. If the OP swaps the cables connected to the 103/110/119 13v and 103/110/119 18v connectors on the SWM8, he will probably see the problem move from the even transponders to the odd ones, indicating the cable/connector issue.
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Posts
    Many
  3. #14
    Join Date
    Dec 27th, 2007
    Posts
    169
    Post Thanks / Like
    Thread Starter
    Ok, the problem was 1 of the 4 wires that go from the LNB to the SWM8. I just swapped all 4 and the problem seems to be solved.
    However, when I run the satellite dish setup, it gives me checks for everything except for 110 Odd. 110 Odd is blank. Also 99 Even shows a red x. The YES network does work now.
    Its definitely not my house wiring, because I ran a direct wire from the SWM8 to the receiver only 20 feet away, just for testing. I haven't yet used the house wiring. All wires that I am using now are brand new Quad Shield RG6.
  4. #15
    Join Date
    Jun 18th, 2011
    Location
    Indiana
    Posts
    1,559
    Post Thanks / Like
    Quote Originally Posted by george99
    The dish still isn't aligned properly. The red X's mean the signals on satellites are not as good as they can be
  5. #16
    Join Date
    Apr 12th, 2006
    Posts
    1,438
    Post Thanks / Like
    ADVERTISING BOX
    Did you read my post? As I posted, once you solved the missing evens problem, you would still have a signal strength issue on 99. 110 odd is blank because there are no 110 odd transponders. 99 is showing a red x on evens because the signals don't meet DirecTv specs. It's an alignment problem, almost certainly nothing else. You need to fine tune the alignment while watching the 99c signal strength screen. Just a very small adjustment should solve the problem without upsetting the 103 signals. Try elevation first, then azimuth.
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
