Results 7 to 12 of 12
Thread: fta sys gets TPs no channels
01-23-2013 10:40 AM #7
SatelliteGuys Freshman
- Join Date
- Apr 21st, 2008
- Posts
- 16
- Post Thanks / Like
- Thread Starter
also tried both USALS or DiSEqC 1.2
01-23-2013 10:40 AM # ADS
Register Today & This Ad Goes Away! Syndicated Advertisement- Join Date
- Always
- Posts
- Many
01-23-2013 11:08 AM #8
With a motorized dish, the LNBF skew is set at zero.
If a blind scan yielded no channels, then either the dish is out of alignment, the LNBF or receiver has failed.
Start by checking that the receiver is outputting 13vdc on a vertical transponder and 18vdc on horizontal.Satellite AV, LLC (Gold Sponsor)
Equipment Development / Distribution / Repair / Call Center
888-483-4673 - http://www.satelliteav.com
eBay Special Deals
Attention Installers: Want more work? Join the Largest Satellite Technician Referral Website - www.FTAinstall.com
01-23-2013 11:11 AM #9
if the dish is on a motor, the skew is at '0'. The motor will rotate and skew the dish/feed correctly.
Aged system - Start over from installation step ONE. Check pole for plumb. etc - etc.One night I walked home very late and fell asleep in somebody's satellite dish.My dreams were showing up on TV's all over the world. -- Steven Wright
Openbox S9, Pansat 3500SD, 139w to 55.5W +30W
10Ft USS Steel BUD and an assortment of P⭐ dishes, 84e(1), .7m(2), 1.2m(2). 2.4m[8ft](1) offset in storage. 🐱
01-23-2013 09:48 PM #10
If you're in a windy place your dish might have slipped a bit on the pole, you might try taking a tv and the receiver out to the dish, makes tinkering a lot easier.
Icon 550, Vantage 1100HD (thanks Stogie) on .90M primestar DG380 motor.10'Sami+GI650 for c-band.
CS5000 now on 1m primestar-polar mount backup system.
Avatar: Bengal tiger. Think you have a real kitty?
01-24-2013 06:11 AM #11
- Join Date
- Apr 21st, 2008
- Posts
- 16
- Thread Starter
thanks everyone! I will try these suggestions
01-25-2013 07:19 AM #12Skylab,
ADVERTISING BOX
If you are logging in TPs when you scan, I would think you would log in some channels as well. Can you recall any of the TP frequencies that you observed being logged in as the scan was progressing?
Maybe the dish/motor is so far out of alignment that it is picking up a nearby satellite with scrambled channels and you are scanning for FTA channels only? Could try scanning for ALL channels and see if it logs in any scrambled ones. Not sure on that, just a thought. Better to try the next suggestion below.
Try dialing in to G19 @ 97.0°W and select TP 12152 H. Can you relay to us what your signal quality level reading is for this TP? You don't need to scan it, just report the quality level detected.
Anyone else have a Fortec Mercury II so that we can judge Skylab's reading from this TP?
Does the Fortec Mercury II allow you to scan a single TP? If you can, go ahead and try that if you seem to detect a strong signal quality on sat G19, TP 12152 H.
Report if you get ANY channels to scan in. That will assist in this process.
I am uncertain at this time as there is insufficient information to base any conclusion upon so far. However, judging from your description, I am inclined to think along the lines that SatAV mentioned regarding a drift in your LNBF's L.O. frequency or the dish/motor becoming out of alignment over time or both.
Did you learn or recall what LNBF type you have or what L.O. frequency it is supposed to be (when new)? Was it 10750?
Well, we will need to accumulate some additional information and clues for sure before we can isolate the problem here. At this point, all of us can only make guesses.
We'll have to wait until you reply with further information from your experimentations.
RADAR
Register To Reply
