Welcome HOME to SatelliteGuys! We are America's Most Popular Satellite Forum!
Results 1 to 5 of 5
Thread: Help from Puerto Rico Antenna 6 feet iverted 180 degress
  1. #1
    Join Date
    Dec 19th, 2006
    Posts
    Post Thanks / Like
    need help with an inverted 180 degrees 6 feet antenna pointing to 129 satellite.
    In Puerto Rico it is difficult to aquire a signal for satellite 129. In normal circumstanes the antenna configuration for satellie 129 is
    Elevation: 17.4 Azimuth (true): 260.8 Azimuth (magn.): 273.7 LNB Skew [?]: 69.5
    very hard to aquire a signal. I inverted the Antenna 180 degrees I know by some reading that in front of the antenna it is 49 degrees using a protractor
    I Do not have such instrument. Can some tell me how to configure the elevation (""remember the elevation"") which behind the Antenna. remember the antenna is inverted 180 degrees.
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Posts
    Many
    Reigster at SatelliteGuys
  3. #2
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! Iceberg did! Help Support The Site And Get Rid of the Syndicated Ads, Iceberg did! If you enjoy the site consider supporting it, Iceberg did! Be COOL like Iceberg and Click a Star and become a Supporting Pub Member today!
    Join Date
    Nov 17th, 2003
    Location
    Parts Unknown
    Posts
    89,701
    Post Thanks / Like
    Do you subscribe to Dish?
    I didnt think 129 even was feasible in Puerto Rico (footprint doesnt reach)
    FOLLOW THE BUZZARDS.....
  4. #3
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! FaT Air did! Help Support The Site And Get Rid of the Syndicated Ads, FaT Air did! If you enjoy the site consider supporting it, FaT Air did! Be COOL like FaT Air and Click a Star and become a Supporting Pub Member today!
    Join Date
    Feb 27th, 2010
    Location
    97W 48N
    Posts
    4,260
    Post Thanks / Like
    Agree, 129W footprint doesn't favor PR.
    http://www.satbeams.com/footprints?position=231
    But here's what I did.(make initial measurement with dish mounted 'normal'.
    INVERTED
    1) Tie a weight on a string long enough to span the vertical face of the dish.
    2) Tape it to the top of the dish hanging over it the face.
    3) Adjust the dish elevation so the string just touches the lower lip.
    Dish face is now straight up and down.
    4) Read the elevation scale. (That's the offset)
    5) Double that reading and add the required elevation.
    6) Invert dish only. Not the elevation mount. (Maybe that's not possible?)
    7) Set elevation scale to what was calculated in 5
    Granted it's not 100% accurate as there's the accuracy of the elevation scales and 'fat fingers' but will get you in the ballpark. (No mathematical 'exactness' and no specialized tools required.) Should get you close enough to proceed with general offset dish alignment.
    I had 30W tuned up in under 30 minutes with an inverted dish using this procedure..
    Give it a shot, think you'll find that this works.
    One night I walked home very late and fell asleep in somebody's satellite dish.My dreams were showing up on TV's all over the world. -- Steven Wright
    Openbox S9, Pansat 3500SD, 139w to 55.5W +30W
    10Ft USS Steel BUD and an assortment of ChannelMaster dishes, (1)84e, (2).7m, (2)1.2m,(1)1.0M, (1)2.4m[8ft] offset in storage.
  5. #4
    Join Date
    Dec 19th, 2006
    Posts
    Post Thanks / Like
    Thread Starter
    Thanks much Fat Air will try your recomendations.
  6. #5
    Join Date
    Aug 7th, 2007
    Location
    Canada
    Posts
    733
    Post Thanks / Like
    Do you know of anyone on the island who was able to receive 129W with only a 6 ft. dish? Reason i'm asking is that satbeams.com is showing the minimum recommended dish size as being 505cm which is 16.5 ft! Honestly, I don't think you have a chance unless you take extreme measures by installing a 16 ft. + dish.
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
