Page 1 of 10 123 ... LastLast
Results 1 to 6 of 59
Thread: Direct tv Error code ?
  1. #1
    Join Date
    Aug 29th, 2006
    Posts
    234
    Post Thanks / Like
    What dose error code 721 Example FS South gettiing it in HD in SD is says error code 721 other sports channels the same way what is this
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Posts
    Many
    Reigster at SatelliteGuys
  3. #2
    Rey's Avatar
    Rey is offline @ your service
    Proud SatelliteGuys Staff Member
    Proud Staff Member
    Join Date
    Feb 8th, 2008
    Location
    Florida
    Posts
    25,235
    Post Thanks / Like
    it means you aren't subscribed to that channel. if you are then you need to call directv and have them resend an authorization to your receivers.
    Dish Member 1999-2008,2013 2-Hoppers w/sling, Directv Member 2008-2013, Sirius Member 2003-2012
    If you like this site and want to help by becoming a pub member click here
    If you're already a pub member and want to only make a donation click here
    Official SatelliteGuys Rules
  4. #3
    Rey's Avatar
    Proud Staff Member
    Join Date
    Feb 8th, 2008
    Location
    Florida
    Posts
    25,235
    Post Thanks / Like
    here's a list of error codes :
    Error Code 711- Access Card not Active
    This is usually associated with a new access card. Tune to channel 377, and verify that the error code still appears?
    Solution 1: Contact DirecTV to have them reactivate the card onto your DirecTV account.
    Error Code 721- Service isn’t Authorized
    Solution 1: Contact DirecTV to have them resend service authorizations to your receiver.
    Solution 2: Contact DirecPath to have them resend service authorizations to your receiver.
    Error Code 722- Service Expired
    Error Code 724- Reciever ID Pairing not Received
    Error Code 726- Wrong or Missing Reciever ID Number
    Error Code 727- Program not Available in your Area
    Error Code 731- Access Card Full
    Solution 1: There is a DirecTV issue related to the VOD or Pay Per View item you ordered. Please contact DirecTV.
    Error Code 733- IPPV Purchase Limit Reached
    Solution 1: There are unrecovered Pay Per View charges on your DirecTV Account. Please contact DirecTV to resolve those charges.
    Error Code 734- Unable to Order IPPV
    Solution 1: Contact DirecTV to have them resend programming to your receiver.
    Solution 2: Contact DirecPath to have them resend programming to your receiver.
    Error code 736- Disabled Due to no Callbacks
    Error Codes 741/742/743- PPV Data was Missing
    Error Code 744- Loss of Programming
    Solution 1: Reset the receiver by pressing the red reset button (located behind the door on the front of the receiver).
    Error Code 746- Possible Data Corruption
    Solution 2: Remove the access card from the receiver (white card inserted next to the reset button). Reset the receiver by pressing the red reset button, then reinsert the access card.
    Error Code 747- Unable to Complete
    User was attempting to order PPV when this error appeared or if they were attempting to use the auto-tune feature?
    Solution 1: If ordering PPV, customer should contact DirecTV customer care.
    Solution 2: If using auto tune, Reset the receiver by pressing the red reset button (located behind the door on the front of the receiver).
    Error Code 750- Service Not Active
    Solution 1: Reset the receiver using the red button (located on the behind the door on the front of the receiver).
    Error Code 761- Insert your Card or MRR Service
    Solution 1: Remove and Reinsert access card.
    Solution 2: Remove the access card and reset the receiver using the red button (located on the behind the door on the front of the receiver). Reinsert the access card.
    Error Code 762- Insert Valid Card or MRR Service
    Error Code 763- Access Card Expired
    Solution 1: Contact DirecTV to have them resend service authorizations to your reciever.
    Solution 2: Contact DirecTV or DirecPath to get service reactivated.
    Error Code 772- Acquiring Guide/Data
    Error Codes 777/780/781- DOD PPV
    Solution 1: If Receiver is networked via Ethernet port, please follow these:
    Error code 777- see Error code 733 process map
    Error code 780- see Error code 731 process map
    Error code 781- see Error code 732 process map
  5. #4
    Join Date
    Aug 29th, 2006
    Posts
    234
    Post Thanks / Like
    Thread Starter
    Rey Tune to channel 377, getting the channel on FS South gettiing it in HD in SD not getting it is says error code 721 other sports channels the same way what is this
  6. #5
    Rey's Avatar
    Proud Staff Member
    Join Date
    Feb 8th, 2008
    Location
    Florida
    Posts
    25,235
    Post Thanks / Like
    Quote Originally Posted by sportman1 View Post
    are you paying for those channels? for sure sportman1? if you are then you need to call directv or send a refresh signal by logging into your directv account.
  7. #6
    Join Date
    Aug 29th, 2006
    Posts
    234
    Post Thanks / Like
    Thread Starter
    Rey yes paying I have the dvrhd 34 Genie is it a good unit ?
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
