Welcome HOME to SatelliteGuys! We are America's Most Popular Satellite Forum!
Results 1 to 4 of 4
Thread: 4K over satellite
  1. #1
    Join Date
    Sep 25th, 2005
    Location
    Palo Alto, CA
    Posts
    254
    Post Thanks / Like
    4K over satellite
    I thought you might all be interested in this:
    http://www.techhive.com/article/2048...me-at-ifa.html
    Eutelsat was demonstrating its 4xHD 4K service and Astra had an HEVC channel setup. The DVB Forum folks said they are moving towards getting HEVC into DVB-S2 rather than defining a new transmission standard. I guess something like DVB-S2 v2.
    I also discovered something I didn't know: DVB-S2 has an optional hierarchical modulation method that allows backwards compatibility with DVB-S receivers. I presume this is something that is not widely used, because I don't recall ever seeing a mention of it.
    MicroHD with Winegard 1m dish, DG380 motor, Geosat Pro SL1 LNB on ku band. 83W to 123W visible.
    Perfect 10 7.5ft C-band dish from 87W to 121W, NS741 LNB controlled by General Instrument 550i analog receiver and Von Weise actuator.
    Been into satellite TV since 1989 (Astra 1A). Started the English-language news service of Tele-Satellit magazine in early nineties.
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
    Reigster at SatelliteGuys
  3. #2
    Join Date
    May 6th, 2005
    Location
    Metro New Orleans, LA
    Posts
    6,569
    Post Thanks / Like
    I wonder how bitstarved that 4k stream was, considering the bitrate needed for reasonable quality 4k...
    Current systems: 3X GEOSATpro microHD PVRs; Digitrans DTE-7150 DVB/Digicipher II; SiliconDust HDHomeRun ATSC/QAM networked tuners; fixed 1 meter Channel Master dish with Eagle Aspen P870 FSS stacked Ku LNB; 2X 3ABN 36" dishes with Sadoun KBSL1 stacked Ku LNBFs on Powermax SG-9120B H-H motors; fixed Sadoun SD180G 1.8 meter dish with Eagle Aspen B1SAT stacked C LNBF; Winegard Square Shooter OTA DTV antenna
  4. #3
    Join Date
    Jul 13th, 2008
    Location
    Wisconsin
    Posts
    2,660
    Post Thanks / Like
    Quote Originally Posted by Tron View Post
    Ought to look great on the iPhone...
  5. #4
    Join Date
    Sep 25th, 2005
    Location
    Palo Alto, CA
    Posts
    254
    Post Thanks / Like
    Thread Starter
    The Eutelsat 4xDVB-S2 system was using 72Mbps in total. I seem to remember Eutelsat has some wideband transponders so I guess it was using one of those.
    The Astra service was running over an 18Mbps stream. The actual stream was constant bit rate but it consisted of a content that was pre-encoded with a variable bit rate that averages 8Mbps. They filled the space with blank data to make the CBR signal to ease the real-time decoding, which was being done by a pre-production decoder chip for future set-top boxes.
    An Astra rep told me he expects two 4K channels per conventional transponder.
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
