Quantcast
getting ready to setup FTA
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Results 1 to 3 of 3
  1. #1
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! K9SAT did! Help Support The Site And Get Rid of the Syndicated Ads, K9SAT did! If you enjoy the site consider supporting it, K9SAT did! Be COOL like K9SAT and Click a Star and become a Supporting Pub Member today!
    Join Date
    Aug 5th, 2004
    Location
    Posts
    12,714
    Post Thanks / Like
    Ok guys im getting ready to buy everything for my FTA setup.. Im going with a 30 in dish, Pole mount, and a motor. Possably adding a fta reciver.. havent decided yet. Im going to Put it on the corner of the bulding that allows me to see everything from 61.5 to 148 with the exception of some trees that would be in the way around 101 - 121... From the spot of the pole mount the trees will be around 30 degrees from ground to tree tops... should be allright ? what do you guys think? What do i need to do becides assemble the dish and put that bad boy up... How do i set the limits and all that good stuff on the motor? These are just some basic questions. I want to beable to hook it up with minor problems.. and start scanning away! Whats a good motor to get? and a good dish.. Im taking a serious look at those lnb's there giving away allthough I have heard that there is a DBS/KU lnb on the way.. Is there one on the market now or should i wait?
    Warning: This is an Old Thread
    This discussion is older than 90 days. information contained in it may no longer be current
    Any posts on this forum are my personal thoughts and do not represent the views or reflections of my current employer!
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
  3. #2
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! Shawn95GT did! Help Support The Site And Get Rid of the Syndicated Ads, Shawn95GT did! If you enjoy the site consider supporting it, Shawn95GT did! Be COOL like Shawn95GT and Click a Star and become a Supporting Pub Member today!
    Join Date
    Feb 9th, 2005
    Location
    Phoenix, AZ
    Posts
    2,278
    Post Thanks / Like
    Grab this software:
    http://www.arachnoid.com/satfinder/
    Get rid of this ad below, as well as the link redirect by becoming a Supporting Pub Member
    It'll give you azmuth, elevation and skew for everything 61.5-148. You should be able to tell of that 30° angle is going to be a problem. If you don't want to grab it post your zipcode and someone will cut/paste the output for ya.
    The
    Sadoun Combo
    looks decent and is pretty cheap.
    For just a little bit more $$ You can get an Invacom LNB, SG2100 and a Winegard dish via this
    seller on ebay
    You can setup the limits on the motor as per the instructions. On my SG-2100 you take it apart to do so.
    My reciever also has a means to set limits.
    If you are using USALS it won't really matter unless you need to keep the dish from hitting the rooftop or something.
    The Winegard is a tried and true dish. You can't really go wrong with it. Iceberg has a review of the 90cm Fortec dishes coming this weeknd and that should be an interesting read.
    So far the Fortec dishes seem to be holding their own. If I could pick it up I think I'd go after a 1.2M Fortec. Since I do have to ship it I'm debating a single 100cm Fortec vs 2x 90cm fortecs with LNBS for about the same money.
    Everyone seems to love the SG2100 motor. I have had nothing but great luck with mine.
    As for LNBs, the lower the noise figure, the better. Invacom owners are raving about them and some of the results I'm seeing seem to warrent the enthusiasm. I want to get one to compare performance against my 'Big Sat' LNB. My trigger finger is itching to pull the trigger and try and get in on the deal for the
    QPH-031 at PSBSatellite
    . This is that combined circular / linear LNB you asked about. I don't think it's quite to market yet but it should be here soon.
  4. #3
    Join Date
    Nov 5th, 2003
    Posts
    Post Thanks / Like
    ADVERTISING BOX
    I use the below to work out if I can clear a tree.
    http://www.bjup.com/services/bjhomesat/tech_support/obstacle.html
    I still like the SG2100 motor, it has pre-set adjustable limit switches, your satellite positions can be stored using USALS or DiSEqC 1.2
    The new cp/lp QPH-031 should be nice when available , its a universal LNBF so for now I would go for a standard LNBF as its always a good idea to have a spare and it can be used to point your dish with a simple satellite meter if you can't see your TV from the dish location.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
