Results 1 to 6 of 6
Thread: Dish 500 Reception
09-02-2005 08:05 PM #1
Dish 500 Reception
I have a Dish Network Dish 500 with 110 and 119. During Hurricane Katrina we had to take down the dish so that it would not blow off the side of the house. I am trying to reconnect my dish but I can't get a signal AT ALL. I have it set at; Azimuth 223, Skew 126, and Elevation is 44 - just it says to set in to in "Point Dish." I have tried calling Dish Network for the last 5 days and it keeps saying "All circuits are busy." So I can't get anyone to help me out. And I will be d****ed if I am going to pay for service I can't receive or get help on. Can anyone of you guys help me PLEASE!!!!!
Warning: This is an Old Thread
This discussion is older than 90 days. information contained in it may no longer be current
09-02-2005 08:05 PM # ADS
Register Today & This Ad Goes Away! Syndicated Advertisement- Join Date
- Always
- Posts
- Many
09-02-2005 08:29 PM #2
Welcome to SatelliteGuys...What Receiver do you have and is your Coax still good?
2013 SatelliteGuys at CES
dfergie@SatelliteGuys.US
For Breaking Satellite Industry News, Please Click Here
09-02-2005 08:45 PM #3
Where are you located at? I'd have to venture that its possible your mast could have been hit by flying debrie unless ofcourse you took the whole assembly down including the mast. If you took the mast down as well then it most likely is not plumb wich will mess with your elevation and skew settings.
As dfergie has inquired have you checked your coax, if there was an open connection on the outside of your home it could have gotten wet and there may be water in the line wich isnt good, you can try draining the water out by hanging the coax so that the end of it points to the ground.
Another thing to consider is wether or not your reciever(s) was on when you disconnected the lnbf from the coax, if the center conductor made contact with any kind of metal that was also touching the shielding of the connector then you could have shorted out the reciever. If the reciever was left plugged in during a power outage it also could have been damaged by a spike from the power coming back on.
09-03-2005 07:17 AM #4
SatelliteGuys Newbie
- Join Date
- Sep 2nd, 2005
- Posts
- 3
- Post Thanks / Like
- Thread Starter
I have a 522 receiver that is used in my living room and master bedroom and a 301 that is used in my guest bedroom.
I have not thought about checking the coax for water damaged. Also, when it's on the original screen, and shows that I have no signal, it will not change transponders. I stays on transponder 26 and does not check for other transponders. The power was already out and the receiver was unplugged when we took down the dish.
09-03-2005 09:21 AM #5
- Join Date
- Sep 2nd, 2005
- Posts
- 3
- Thread Starter
I am located in Daphne, AL 36526
09-03-2005 09:49 AM #6Neither Receiver works? and did you just take down the Dish and leave the Mast... as Van suggested if you did that, might need to check and make sure it is perfectly level
ADVERTISING BOX
Register To Reply
