Quantcast
Mounting dish and motor to pipe????
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Results 1 to 5 of 5
  1. #1
    Join Date
    Sep 3rd, 2005
    Location
    Jensen Beach, FL
    Posts
    166
    Post Thanks / Like
    Can someone tell me if I should take the short curved pipe off of the dish motor if I am going to mount it to a plumb pipe in the ground? Will the motor be positioned correctly if I mount it directly to the pipe? The pipe is 1 5/8 " and should fit the motor perfectly. As hard as I look at it, I can only think that the curved pipe should not be there for the way I want to mount it. Thanks , Joe
    Warning: This is an Old Thread
    This discussion is older than 90 days. information contained in it may no longer be current
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Location
    Advertising world
    Posts
    Many
  3. #2
    Join Date
    Jul 8th, 2004
    Location
    Virginia Beach
    Posts
    9,355
    Post Thanks / Like
    This sounds like a c band or ku band dish with a motor for vertical and horizontal adjustments to see satellites at various locations, you may want to ask the mods to move this thread to the c - band forum and post a picture and detail a little more as to what your outcome is that your seeking.
  4. #3
    Join Date
    Sep 3rd, 2005
    Location
    Jensen Beach, FL
    Posts
    166
    Post Thanks / Like
    Thread Starter
    No, it is a 36" Fortec dish, and a HH motor from Sadoun.com I look through the various threads and found a few pictures of dish setups that show the motor mounted direct to the plumb pipe. The only problem I cam accross tha might make me change my plan is that they all suggested a 2 3/8 pipe to keep the motor weight from taking the pipe out of plumb. I think I am going to fill the pipe with concreate to make it hold its plump position. Does anyone think this is a bad idea? I don't see how my 1 5/8 pipe can bend once the concrete gets hard inside of it. Joe
  5. #4
    Join Date
    Nov 5th, 2003
    Posts
    Post Thanks / Like
    Moved from the General area.
    No need for the mast/Curved pipe if you are going to mount the motor directly to a pole in the ground. 1 5/8" should work if filled with concrete. I routinely use 2" pipe with no problem. I also fill my poles with concrete : )
  6. #5
    Join Date
    Sep 3rd, 2005
    Location
    Jensen Beach, FL
    Posts
    166
    Post Thanks / Like
    Thread Starter
    ADVERTISING BOX
    I discovered a major problem in motor control. This would be that the old motor worked fine through the Diplexer's, but the new Stab motor did not work until I bypassed the Diplexer's. Signal was not a problem in either case, but the motor would not move until I removed the diplexers. Joe
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
