Quantcast
Is this 1 DISH soulition possible for more HD & SD channels????
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Results 1 to 3 of 3
  1. #1
    Join Date
    Nov 7th, 2003
    Posts
    24
    Post Thanks / Like
    Is this 1 DISH solution possible for more HD & SD channels????
    With the Superdish is it possible to view 4 satellites if they are closer together. This would avoid the two DISH solution.
    See thread below (on dsb talk) regarding the following request by DISH.
    (*EchoStar has applied for authority to construct, launch and operate DBS satellite assets in the 12.2-12.7 GHz (high-power Ku-Band frequency) and 17.3-17.8 GHz frequency bands at 123.5 degrees, 96.5 degrees and 86.5 degrees, the FCC said. The applications were filed in June, though they have not yet been accepted for filing at the FCC)
    http://www.dbstalk.com/showthread.ph...&highlight=fcc
    Get rid of this ad below, as well as the link redirect by becoming a Supporting Pub Member
    Just a hopefull thought!!!!!
  2. #2
    Join Date
    Sep 7th, 2003
    Location
    Moreno Valley, CA
    Posts
    1,809
    Post Thanks / Like
    I am no expert in this but my understanding is that for the FSS (low power) ku band frequencies the LNB on the dish needs to be in the "prime focus" area of the dish. This is what the superdish does - it is aimed directly at the 121 or 105 degree position then the DBS LNBs are off to one side. IF E* is able to get authorization to use DBS frequencies at 123.5, 96.5, and 86.5 degrees (a tough sell to the FCC IMHO) then a superdish would be able to see anything in its almost 30 degree arc as long as there was an LNB in place to receive it.
  3. #3
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! mike123abc did! Help Support The Site And Get Rid of the Syndicated Ads, mike123abc did! If you enjoy the site consider supporting it, mike123abc did! Be COOL like mike123abc and Click a Star and become a Supporting Pub Member today!
    Join Date
    Sep 25th, 2003
    Location
    Wichita Falls, TX
    Posts
    13,452
    Post Thanks / Like
    ADVERTISING BOX
    I think the main new DBS slot that dish wants to put in place is 105.5. They have already paid SES a deposit for a "future" DBS satellite to go in a yet to be decided on spot. The FCC is working on the project now. Under consideration are spacing and power issues. For example the current DBS slots could be unlimited power (well within reason) and the "tweener" slots are limited to 100watts, or have a different polarization.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
