Page 1 of 2 12 LastLast
Results 1 to 6 of 7
Thread: RG6 rating question...
  1. #1
    Join Date
    Sep 21st, 2005
    Posts
    8
    Post Thanks / Like
    We are getting ready to run a new rg6 cable to my box. The manual says to use rg6 cables rated for 950-2150 MHz. The cable we bought says swept to 3.0 ghz. Is this the right cable? Thanks!
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Posts
    Many
    Reigster at SatelliteGuys
  3. #2
    Join Date
    Nov 20th, 2003
    Location
    Seattle, WA
    Posts
    545
    Post Thanks / Like
    Yes that cable is fine.
  4. #3
    Join Date
    Sep 21st, 2005
    Posts
    8
    Post Thanks / Like
    Thread Starter
    Thank you so much for the quick reply!!
  5. #4
    Join Date
    Aug 17th, 2005
    Posts
    84
    Post Thanks / Like
    I think what swept means is that a sample of that cable is tested by sending a signal from say 5 Mhz to 3,000 Mhz (3 Ghz) and seeing what the cable's response is. This basically determines if the cable stays at a 75 Ohm impedance over the frequency range and means that the loss versus frequency is gradual as it should be. The best specification would also mention what the SRL (Structural Return loss) is. This is a measure of impedance (Ohmage) or SWR. I think the best hardline cables for cable tv have an SRL of 30 db but RG type cables are more typicaly spec'd around 26 db SRL. I believe this also means if a cable has a signal on it, the imperfections in the cable will cause an echo signal to be set up that is 30 or 26 db weaker than the signal going in the forward direction. For analog video signals this shows up as a weak ghost to the right of the wanted signal- the more offset the ghost is the further away the mismatch is. For referance a direct short or a cable that is open (not terminated in a 75 Ohm load) has an SRL of 0 db meaning that the reflected echo is the same strength as the forward signal hitting the open or short.
  6. #5
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! Stargazer did! Help Support The Site And Get Rid of the Syndicated Ads, Stargazer did! If you enjoy the site consider supporting it, Stargazer did! Be COOL like Stargazer and Click a Star and become a Supporting Pub Member today!
    Join Date
    Sep 7th, 2003
    Location
    Western WV
    Posts
    15,174
    Post Thanks / Like
    So, will a cable not rated for 2.25 GHZ (2250 MHZ) not work with the Dish1000? I remember that DP required that rating in order to work. The manual does in fact state 950-2150 so would 950 work? I wonder why it would work with a Dish1000 but not other DP configurations? Is it due to it being DPP?
  7. #6
    Join Date
    Aug 17th, 2005
    Posts
    84
    Post Thanks / Like
    If Dish 1000 uses frequencies above 2.25 GHz you'll find distance limitations with the cable rated to only 2.25 GHz. What I'm saying is if a particular spec says you can only use 200 feet of cable between the dish and receiver using cable that's not rated to your upper limit will mean that it will not work at distances less than 200 feet OR said another way: you can get away with not rated cable for short distances it's the longer lengths that will cause you problems.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
