Results 1 to 4 of 4
Thread: XM Antenna cable and how long can it go?
  1. #1
    Join Date
    Oct 20th, 2004
    Posts
    349
    Post Thanks / Like
    I am moving my office in my house from the western side to the eastern side which has windows that would allow for my XM PCR antenna to face the proper direction for the reception. Something like southwest or south east is the correct direction.
    So, the theory I had was to run an antenna wire, from the new location of the PC to the side of the house with a proper exposure and then use an outdoor antenna to connect it and then possibly mount it on the side of the house. I might also try and force the antenna to work out a back window of the house.
    All of this is going to happen on the second floor, so roof access is not that bad as well as a full sized walk in attic could be used.
    The bottom line question is that with wiring this, it might go something like 30 or 40 feet considering its going to go up a wall, then across a wall down a wall and so on to get to its destination.
    Any thoughts ?
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Posts
    Many
    Reigster at SatelliteGuys
  3. #2
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! minorthr did! Help Support The Site And Get Rid of the Syndicated Ads, minorthr did! If you enjoy the site consider supporting it, minorthr did! Be COOL like minorthr and Click a Star and become a Supporting Pub Member today!
    Join Date
    Jun 8th, 2004
    Location
    Pa
    Posts
    1,122
    Post Thanks / Like
    You can get a cable extender they can be daisy changed together to go to around 400 feet
    http://www.myradiostore.us/antennas-...oot-skyfi.html
    . Or you could go with one of those personal repeaters.
    http://www.myradiostore.us/antennas-...-repeater.html
    The cable is the much cheaper solution.
    I reject your reality and substitute my own.
    [XBL]minorthr[/XBL]
  4. #3
    Join Date
    Mar 7th, 2005
    Location
    DONORA PA
    Posts
    2,656
    Post Thanks / Like
    when i did the XM kiosks at the malls , the run of coax they provided was 200 feet. no problem with reception.
    you will be fine at 40 feet
  5. #4
    Join Date
    Oct 20th, 2004
    Posts
    349
    Post Thanks / Like
    Thread Starter
    Quote Originally Posted by dragon002
    Awesome guys ... thanks.. I will be able to get all set up before I move the office so I should have no down time
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
