Results 1 to 6 of 6
Thread: My new sg2100
01-15-2006 10:07 AM #1
My new sg2100
Could someone help I need my motor settings for zip 26651 and my true south sat is nim2 and is dbs i do not have a dbs lnb could i use amc5 to setup and tune will it track right . Also my dish settings. Thanks you great helpful site.
01-15-2006 10:07 AM # ADS
Register Today & This Ad Goes Away! Syndicated Advertisement- Join Date
- Always
- Location
- Advertising world
- Posts
- Many
01-15-2006 10:13 AM #2
Motor elevation = 52 deg (The other side of the motor will be same as your Latitude(38 deg.)
Dish Elevation = 24 deg.
Code:Summersville, WV 26651 Latitude 38° 18.054'N Longitude 80° 50.118'W Sat Name Sat Lng Az(t) Az(m) El Skew ----------------------------------------------------- 12.5°W Atlantic Bird 12.5W 103.8 112.1 8.2 -49.6 Telstar 12 15.0W 105.5 113.8 10.2 -49.1 Intelsat 901 18.0W 107.6 115.9 12.5 -48.4 NSS 7 22.0W 110.5 118.8 15.6 -47.3 Intelsat 905 24.5W 112.4 120.7 17.5 -46.5 Intelsat 907 27.5W 114.8 123.0 19.8 -45.4 Hispasat 1C/D 30.0W 116.8 125.1 21.6 -44.5 Intelsat 801 31.5W 118.0 126.3 22.7 -43.8 Intelsat 903 34.5W 120.6 128.9 24.9 -42.5 AMC 12/T 11 37.5W 123.3 131.6 27.1 -41.0 NSS 806 40.5W 126.1 134.4 29.1 -39.3 Pas 3R/6B 43.0W 128.6 136.9 30.8 -37.8 Pas 1R 45.0W 130.6 138.9 32.2 -36.5 Intelsat 705 50.0W 136.1 144.3 35.3 -33.0 Intelsat 707 53.0W 139.6 147.8 37.0 -30.6 Intelsat 805 55.5W 142.6 150.9 38.4 -28.4 Pas 9 58.0W 145.8 154.1 39.6 -26.2 Amazonas 61.0W 149.8 158.1 41.0 -23.3 EchoStar 3 61.5W 150.5 158.8 41.2 -22.7 Rainbow 1 61.5W 150.5 158.8 41.2 -22.7 Nahuel 1 71.8W 165.6 173.9 44.6 -11.2 DirecTV 1 72.5W 166.7 175.0 44.8 -10.4 AMC 6 72.0W 165.9 174.2 44.7 -11.0 Galaxy 12 74.0W 169.1 177.3 45.1 -8.6 SBS 6 74.0W 169.1 177.3 45.1 -8.6 GOES 12 75.0W 170.6 178.9 45.2 -7.3 AMC 5 79.0W 177.0 185.3 45.6 -2.3 DirecTV 3 81.8W 181.6 189.8 45.6 1.2 Nimiq 2 82.0W 181.9 190.1 45.6 1.5 AMC 9 83.0W 183.5 191.8 45.6 2.7 Brasilsat B3 84.0W 185.1 193.4 45.5 4.0 AMC 2/16 85.0W 186.7 195.0 45.4 5.3 AMC 3 87.0W 189.9 198.2 45.2 7.7 IA-8 89.0W 193.0 201.3 44.8 10.2 Galaxy 11 91.0W 196.1 204.4 44.4 12.6 Nimiq 1/3 91.0W 196.1 204.4 44.4 12.6 Brasilsat B4 92.0W 197.7 205.9 44.1 13.8 Telstar 6 93.0W 199.2 207.4 43.8 14.9 Galaxy 3C 95.0W 202.2 210.4 43.2 17.2 Telstar 5 97.0W 205.1 213.3 42.5 19.4 Galaxy 4R 99.0W 207.9 216.2 41.7 21.5 DirecTV 1R/4S/8 101.0W 210.6 218.9 40.9 23.6 AMC 4 101.0W 210.6 218.9 40.9 23.6 Spaceway 1 102.0W 212.0 220.3 40.4 24.6 AMC 1 103.0W 213.3 221.6 40.0 25.5 AMC 15 105.0W 215.9 224.2 39.0 27.4 Anik F1/F1R 107.3W 218.8 227.0 37.8 29.4 DirecTV 6 109.5W 221.4 229.7 36.5 31.3 EchoStar 6 110.0W 222.0 230.3 36.3 31.7 EchoStar 8 110.0W 222.0 230.3 36.3 31.7 Anik F2 111.1W 223.3 231.5 35.6 32.5 Solidaridad 2 113.0W 225.4 233.7 34.5 34.0 SatMex 5 116.8W 229.5 237.8 32.1 36.6 DirecTV 5 119.0W 231.7 240.0 30.6 38.0 EchoStar 7 119.0W 231.7 240.0 30.6 38.0 EchoStar 9/Telstar 13 121.0W 233.7 242.0 29.3 39.2 Galaxy 10R 123.0W 235.6 243.9 27.9 40.4 Galaxy 12 125.0W 237.5 245.7 26.5 41.4 Galaxy 13/H 1 127.0W 239.2 247.5 25.0 42.4 Telstar 7/Echostar 5 129.0W 241.0 249.2 23.6 43.3 AMC 11 131.0W 242.7 250.9 22.1 44.2 Galaxy 1R 133.0W 244.3 252.6 20.6 45.0 AMC 10 135.0W 245.9 254.2 19.1 45.7 AMC 7 137.0W 247.4 255.7 17.6 46.4 AMC 8 139.0W 249.0 257.2 16.1 47.1 EchoStar 1 148.0W 255.4 263.6 9.1 49.4 EchoStar 2 148.0W 255.4 263.6 9.1 49.4 ............................................................ *** DBS SATELLITE *** EchoStar 3/R1 61.5W 150.5 158.8 41.2 -22.7 EchoStar 6/8 110.0W 222.0 230.3 36.3 31.7 EchoStar 7 119.0W 231.7 240.0 30.6 38.0 EchoStar 9/Telstar 13 121.0W 233.7 242.0 29.3 39.2 EchoStar 5 129.0W 241.0 249.2 23.6 43.3 EchoStar 1/2 148.0W 255.4 263.6 9.1 49.4 Nimiq 2 82.0W 181.9 190.1 45.6 1.5 Nimiq 1/3 91.0W 196.1 204.4 44.4 12.6 DirecTV 1R/4S/8 101.0W 210.6 218.9 40.9 23.6 DirecTV 5 110.0W 222.0 230.3 36.3 31.7 DirecTV 7S 119.0W 231.7 240.0 30.6 38.0 Satellite Finder is (c) Copyright 2004, P. Lutus
If you have USALS there will be no problem using AMC-5 as a true south satellite
01-15-2006 10:21 AM #3
SatelliteGuys Freshman
- Join Date
- Feb 21st, 2005
- Location
- summersville wv
- Posts
- 5
- Post Thanks / Like
- Thread Starter
I do not have USALS. I have a DMT-2050 rec. for now hope to have a new one soon.
01-15-2006 10:28 AM #4
What you may have to do then if you can't find/borrow a DBS LNBF, is move the motor slightly to the east by 2 deg. then peak your signal on AMC-5
It will be a balancing act but should be doable, most of the systems I have set up did not have USALS! But in saying that we are real lucky here with an exact KU True south satellite.
Good Luck!
Good Idea to have AMC-5 already stored on your receiver before you add the motor!
01-15-2006 10:34 AM #5
- Join Date
- Feb 21st, 2005
- Location
- summersville wv
- Posts
- 5
- Thread Starter
Thanks so much for the help i my need more later when i start the setup to cold now just getting things together thanks.
01-15-2006 10:36 AM #6
ADVERTISING BOX
Always someone here to help!
Register To Reply
