Results 1 to 6 of 7
Thread: Dish 1000 signal in Seattle area
01-18-2006 04:25 PM #1
01-18-2006 04:36 PM #2
try peaking it with 129 satellite, you might compromise signal on 119 and 110 but not much. or put separate dish for 129.
01-18-2006 04:38 PM #3
make sure your mast leveled, and tight and there is nothing in front of the dish. check your setting ( elevation and skew)
01-18-2006 05:31 PM #4
rixhd,
The readings for 129 are on the low side for us in the West coast. You could probably do better and should try peaking it but don't expect a great improvement. Most of my TPs on 129 are in the lower 80s and 20 and 21 (our locals) are in the low 70s. I have a separate D500 for 129.
BTW, nice graphic.
01-18-2006 06:12 PM #5
rixhd,
My numbers are very similar to yours.
My 921 connects to my Dish 1000 and 148 dish via a DP44 switch.
No dropouts except when the seaplanes fly through the signal (I'm on Lake Union).
01-18-2006 07:08 PM #6I'm in Mill Creek. My numbers were about the same initially with my dish 1000. The installer did a tweak on the skew (now at 89). That helped a little but numbers wise not a big change. I'm not seeing dropouts and that's the main thing for me.
ADVERTISING BOX
Register To Reply
