Results 1 to 5 of 5
Thread: burn in
03-04-2006 12:57 PM #1
burn in
Will widescreen movies on dvd burn in on a rptv 52inch
03-04-2006 12:57 PM # ADS
Register Today & This Ad Goes Away! Syndicated Advertisement- Join Date
- Always
- Posts
- Many
03-04-2006 02:09 PM #2
You should not have that issue with a rear projection style tv.
It's the plasmas you have to worry about on the burn-in. LCDs will give you dead pixels... RPTVs will have a burned out lamp, or just a dimmer picture till the bulb goes out...
03-04-2006 02:31 PM #352inch. Is it a 4x3 CRT RPTV? If so, then yes, burn-in might be an issue. Turning down the contrast level may reduce the risk.
Originally Posted by carlosg
Ilya @ SatelliteGuys.us
03-04-2006 02:44 PM #4Rear projections will definitely get burn in with the black bars. Been there, done that.
Originally Posted by jbcheshire
03-05-2006 11:57 AM #5
ADVERTISING BOX
Don't know where you got your Info from?
But ....YES....a RPTV can get "Burn-in" !!
http://www.avsforum.com/avs-vb/showthread.php?t=406182
Get rid of this ad below, as well as the link redirect by becoming a Supporting Pub Member
Register To Reply
