Quantcast
LNB amplifier
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Results 1 to 5 of 5
Thread: LNB amplifier
  1. #1
    Join Date
    Jun 27th, 2005
    Location
    Seguin, Texas
    Posts
    934
    Post Thanks / Like
    Question LNB amplifier
    I found this amplifier on ebay. In the ad it has a before and after picture. Will the amp really do that as the pictures show?
    Here is the link
    http://tinyurl.com/kofu8
    Get rid of this ad below, as well as the link redirect by becoming a Supporting Pub Member
  2. #2
    Iceberg's Avatar
    Iceberg is offline The No Pain Train
    Proud SatelliteGuys Staff Member
    Proud Staff Member
    Join Date
    Nov 17th, 2003
    Location
    A Chicken Farm in Sandy Fork, Delaware
    Posts
    86,688
    Post Thanks / Like
    no because FTA is digital. That shows an analog picture. Digital has no snow.
    I've seen amps actually HINDER signal
    Directv Slimline SWM 5 LNB and DirectvWorld dish on the roof of the apartment building...Directv HR34 AKA Genie
    All FTA stuff in storage right now
  3. #3
    Join Date
    Jun 27th, 2005
    Location
    Seguin, Texas
    Posts
    934
    Post Thanks / Like
    Thread Starter
    Thanks Ice....
  4. #4
    Join Date
    Apr 28th, 2005
    Posts
    324
    Post Thanks / Like
    The only time you want to use an amplifier is if you have an extremely long cable run and your experiencing signal loss over it. Another situation might be where you use splitters to feed the same singal to many receievers. Other than those situations you should probably stay away from amplifiers as they themselves will add some noise to the signal. So, if you don't need an amplifier and you still use one anyway, your just going to make your signal quality worse instead of better by adding more noise.
  5. #5
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! red hazard did! Help Support The Site And Get Rid of the Syndicated Ads, red hazard did! If you enjoy the site consider supporting it, red hazard did! Be COOL like red hazard and Click a Star and become a Supporting Pub Member today!
    Join Date
    Oct 13th, 2003
    Location
    St Louis Metro East (Illinois)
    Posts
    484
    Post Thanks / Like
    It's Doubtful it will Help
    ADVERTISING BOX
    Quote Originally Posted by Gary Z
    Here is the link
    It should work with digital services such as so-called FTA, plus Echostar and DirecTV because the output of the LNBF is analog and NOT digital. The digital signal occurs at the output of the demodulator inside the receiver. However, there are other issues besides signal strength - - the main issue being carrier to noise ratio. Further amplification adds to the noise and reduces the C/N. I would bet the noise factor in that inexpensive amp is rather high.
    Since virtually all satellite consumer video services are digital, those pictures are "doctored up". Digital systems have almost no margin between a "perfect picture" and no picture. The best way to improve signal strength (and C/N) is with a larger satellite dish. A LNB with a lower noise factor helps C/N a little too. High quality low loss coax, short coax runs, quality connectors, and minimal connections helps minimize loss of signal strength.
    NOTE: A "perfect picture" is defined as how the satellite service provider intended the picture to be received.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
