Results 1 to 6 of 11
Thread: Need Help with HD Networks!
07-27-2006 04:37 PM #1
I have basic cable from Comcast and I am trying to see if I get the HD network channels. When I hook up the cable to my plasma Cable Input I only see the SD channels. When I hook up the cable to my plasmas ATSC Tuner I get nothing ( works for OTA HD). Any suggestions? Am I not connecting things correctly? Any help would be appreciated.
Warning: This is an Old Thread
This discussion is older than 90 days. information contained in it may no longer be current
07-27-2006 04:37 PM # ADS
Register Today & This Ad Goes Away! Syndicated Advertisement- Join Date
- Always
- Location
- Advertising world
- Posts
- Many
07-27-2006 04:45 PM #2
If you are referring to a regular COAX incoming line into just the back of TV, that will do you no good. The ATSC input should be for an OTA antenna, not your cable companies line.
What cable box make & model? You need the COAX line to go into the cable box (probably a upgraded specific box) and then have a either a component or HDMI, or DVI line out from that box to a corresponding jack on your TV.DirecTV HR22, H21, H23, HR20, Sanyo PLV-Z 119", Acer H5360 106", Samsung PN51D450 51", Insignia NS-51P680A12 51", Onkyo TX-NR708, Onkyo HT-R550, Yamaha RX-Z, Sony BDP-S570, Sony PS3 (x2), D-Link Gigabit Network, ViaTalk Unlimited Everything VoIP ($13/mo)
07-27-2006 04:50 PM #3
- Join Date
- Jul 7th, 2004
- Location
- Lancaster PA
- Posts
- 48
- Post Thanks / Like
- Thread Starter
No Cable Box. That was what i was trying to avoid. I only have basic cable because I use Comcast for Internet. Most of my TV watching is done through a dish network DVR (model 510). I thought I could avoid the cable box because of the built in tuner on the Plasma (Viore).
07-27-2006 04:53 PM #4
Then you need a correctly selected and setup OTA antenna for your zip code location, or upgrade your Dish Network.
07-27-2006 04:57 PM #5
Does your TV have a built-in QAM tuner? (Does it have a place for a cable card?) If so, then you COULD get your local stations in HD. If not, then you have to have a cable box.
07-27-2006 05:12 PM #6
- Join Date
- Jul 7th, 2004
- Location
- Lancaster PA
- Posts
- 48
- Thread Starter
No QAM tuner
ADVERTISING BOX
No cable card. Any way to buy an external QAM tuner and hook that up? I don't want to pay an additional monthly fee to Comcast.
Register To Reply
