Quantcast
SW64 problem
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Results 1 to 4 of 4
Thread: SW64 problem
  1. #1
    Guest
    SW64 problem
    I have a 5000, 6000 and 721 connected to a SW64 from a Dish500 and 61.5 dish.
    All three receivers are failing the switch test (input 2B, and even channels on 110 are gone). I replaced the SW64 (not the power inserter) but get the same thing with the new one installed. I have swapped the 2A and 2B inputs at the SW64, thinking it might be the LNB but the switch test still fails input 2B.
    Any clue what is happening ?
    Are the next steps to replace the power inserter then remove the receivers one at a time ?
    Warning: This is an Old Thread
    This discussion is older than 90 days. information contained in it may no longer be current
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
  3. #2
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! K R Kimmel did! Help Support The Site And Get Rid of the Syndicated Ads, K R Kimmel did! If you enjoy the site consider supporting it, K R Kimmel did! Be COOL like K R Kimmel and Click a Star and become a Supporting Pub Member today!
    Join Date
    Sep 19th, 2003
    Location
    Beaver County, PA (suburban Pittsburgh)
    Posts
    185
    Post Thanks / Like
    It sounds to me like you do have a bad LNB. The way the sw64 works is by commanding the each of the inputs to request a specific connection to the LNB it is wired to. The "B" inputs always request the even numbered transponders. I suspect the LNB is not responding to the command to switch to even transponders.
    You will probably need to swap out the LNB.
  4. #3
    Join Date
    Oct 16th, 2003
    Posts
    99
    Post Thanks / Like
    Could also be the power inserter since you didn't replace that! If it is not working at all or putting out lower power then it should it would give you similar errors.
  5. #4
    Join Date
    Oct 28th, 2003
    Location
    Sacramento, California, United States
    Posts
    125
    Post Thanks / Like
    ADVERTISING BOX
    And make sure the lead that carries that power to that switch doesn't have any faults itself. Bad or loose connectors, bad coax. Check it all. I've ran around a house 1 whole day on a nightmare similar to yours. Then I refitted the connector to the power injector.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
