Results 1 to 3 of 3
Thread: Long Cable runs and configuration.
  1. #1
    Join Date
    Oct 2nd, 2004
    Posts
    Post Thanks / Like
    I'm currently building a home on a 5 acre parcel that's frought with 200+ foot Pines and Cedars. The only place where I've got a shot at the Southern sky is on my property's Southern border. That location is up to 500 feet from my home.
    Is there equipment/configurations I could install that would mitigate the signal loss/other issues with this long cable run?
    Suggestions please??
    Thanks,
    Tom
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Posts
    Many
    Reigster at SatelliteGuys
  3. #2
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! cheebs did! Help Support The Site And Get Rid of the Syndicated Ads, cheebs did! If you enjoy the site consider supporting it, cheebs did! Be COOL like cheebs and Click a Star and become a Supporting Pub Member today!
    Join Date
    Oct 15th, 2005
    Posts
    223
    Post Thanks / Like
    Run RG-11 cable, or use one of the new fiber optic transmitters. Pace
    www.pacemso.com
    has them.
    The fiber solution is, of course, more elegant, but also pricier. Even the RG-11 solution is pricey, especially if you are planning on using the Ka/Ku dish.
  4. #3
    Join Date
    Jan 4th, 2005
    Location
    Alabama
    Posts
    297
    Post Thanks / Like
    Quote Originally Posted by seniormoments View Post
    Thanks,
    Tom
    It might serve you better to go UP rather than OUT from the house. A antenna tower only has to be high enough to get an angle where the dish can see over the top of the trees (you should clear a few trees within the line of sight which would greatly reduce the height of the tower). The shorter the tower the less coax length needed and it would most likely be able to get by with no signal boosting devices or oversized coax.
    Once you add up the number of 500+ foot lengths of oversized coax needed, PVC pipe to run the coax through, access ports at various places along the length of the run for servicing the coax if needed (you don't want to have to replace an entire 500 foot coax if it is damaged and can be spliced in one sopt, right?), trenching & burial and any needed signal booster, the cost would be nearly equal to if not more than that of a antenna tower, installation, removing a few trees and the coax needed to run to the house. Only problem I see is finding a tech who is willing and able to climb a tall tower to install the dish (and hope the tower is stable enough that his climbing up & down the tower doesn't affect the alignment of the dish).
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
